had a weird problem with uc2825 / sg3525 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th October 2005, 08:28 AM   #1
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
Default had a weird problem with uc2825 / sg3525
i'm making a new smps so i've tested the PWM chips with my new scope
and something weird was happening :
output B was ok and output A had spikes only , no square wave
i tried both the sg3525 and the uc2825 and the same thing was happening , only one output is working and it was output B on both chips ...
i've changed the chips million times , and was going like
finally i found the problem , i used 2 regular BNC cables with the scope , i've changed one to a 60mhz probe and it started to work .
now i have couple questions :
both outputs of the chip are identical ,how can it be that out B is working with normal probe and out A isnt?
the same is happening with sg3525 ...
update :
i have added a 1K resistor in series with a normal BNC and it worked fine , what is going on here ?
also , do u think i've damaged the chips?
if you are not living on the edge you are taking too much space
Old 17th October 2005, 06:34 PM   #2
subwo1 is offline subwo1  United States
subwo1's Avatar
I am wondering if I damaged an SG3525 chip as well since, under a light load, the duty cycle is not staying at maximum even though the feedback is disabled right now.
It seems strange how your probes are acting on your circuit. It is great you have scope now, though.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 17th October 2005, 07:17 PM   #3
sss's Avatar
i figured out what was the problem .....
i used an old pc power supply and didnt use any caps on the Vcc pin of the chip , so when i was connecting the probe the signal stopped because in a split of a second the voltage dropped because of the load (the probe) and the chip entered under voltage lockout condition
it started to happen on output b also , then i figured it
now all working fine , even with a regular probe
so i didnt damage anything
Old 17th October 2005, 07:47 PM   #4
subwo1's Avatar
It makes sense now.
USMPS
Old 18th October 2005, 12:32 PM   #5
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
There is a little lesson to learn there: when you connect a probe to any node of a circuit, you are always inserting some parasitistic capacitance that may change circuit behavior sometimes.
Old 28th November 2005, 04:53 PM   #6
Send a message via AIM to shon35us Send a message via MSN to shon35us Send a message via Yahoo to shon35us
Default What size cap did you use
I'm having the same problem, however I do not have a 60 Mhz probe. Should the circuit have a cap across the battery line, and if so what size. Also the SG3525 get loaded down with the scobe probe but ok. That just seems kinda strange but ok. Any help with the circuit I will be more than happy.
Thank you
SG3525 problem ifrythings Power Supplies 36 12th December 2013 07:30 AM
SG3525 problem lorenzo_cy Power Supplies 7 19th April 2007 07:42 AM
Weird Amp Problem Stewart8989 Car Audio 3 6th April 2007 07:54 AM
Weird PSU problem phn Power Supplies 8 6th February 2007 03:42 AM
Weird amp problem Etnoo Car Audio 5 22nd August 2006 07:26 AM
Copyright 1999-2017 diyAudio
