I did not see any topics on this subject in the search. I don't think DACs count as power supplies. Sorry if I'm just adding to the noise.
I'm building a circuit for use in automotive apps that bears a resemblance to an audio circuit. The problem is that I need a bipolar supply. I want to keep the part count lo so the end result can be built into a small package. The system will function just above the audio range and will not be driving a speaker. I'm not looking for tons of current here either, I haven't pinned down any specs yet, but I doubt I'll exceed 5 amps, if I even get that high. Any simple solutions for converting to bipolar and regulating that power? I'm working on a 10 volt rail to rail assumption now, though adapting the system to handle a little more votage if I can get it and cut down on the current. What solutions are avilable? |
#2 |
Electrons are yellow and more is better!
What is your load? Is it grounded or can it be floating? Is it a motor you want to rotate in both directions?
If you don't want to fix negative voltage you have to consider a bridged solution, linear or PWM.
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
| Unipolar vs complementary input stage | Steve Eddy | Solid State | 270 | 4th March 2012 05:54 AM |
| Using bipolar opamps | speakerguy79 | Solid State | 2 | 16th March 2007 03:48 PM |
| "unipolar" to bipolar loudspeakers | Daniel-A | Multi-Way | 0 | 7th April 2004 01:14 AM |
| How does this bipolar look? | punchpeanut | Solid State | 11 | 2nd October 2003 07:48 AM |
