Is the following correct?
IF
IF
- an op-amp has a listed voltage noise of 3 nV/rqrtHz
- used with a gain of 100
- the conditions are such that the voltage noise dominates
- further ignore 1/f and just consider wideband white noise
- I take the FFT of the output noise
[/list=1]
THEN
the noise floor should be observed at 3nV * 100 = 300nV = -130 dB
AND
the rms voltage is equal to 3nV* sqrt(bandwidth)
there is an additional BW effect in the fft definition, if the bin size is ~ 1 Hz then your estimate is roughly correct - figure bin size from time duration of data set/#points in fft
also be aware that various math packages use different normalizations; you may see 1/n or sqrt👎 used
input refered noise is en*sqrt(bw) output noise will be 100x larger
it is quite an accomplishment to totaly remove power line fundamental and harmonics at these levels
