#11 | |
can you explain this a bit more, please.
Looks like Sponge Bob has killed another thread. |
#12 | |
if you fail to properly terminate the RFI can cause bizarre behavior in opamps and discrete devices -- the folks at Analog Devices describe an amusing story of how a hand-held 2 meter (144 MHz) transceiver caused havoc with some instrumentation amplifiers which had not been properly bypassed. Eva's example of a pulsed V or I application is certainly correct in a high efficiency SMPS -- I think that it breaks down for a Class A or AB1 amplifier driven from the mains -- we are now at that point in the life-cycle of SMPS designers (roughly coinciding with the advent of the IBM AT in 1980) to see whether there is an outbreak of mass insanity resulting from the failed efforts to stanch all instances of EMI, RFI etc. |
#13 |
Well, if the antenna is terminated into a low impedance in the capacitor bank side, won't we still have picked up RF at the other side in the amplifier module?
Note that the major source of high frequencies inside an audio amplifier is the output stage when it oscillates or a considerable amount of trebble is being amplified (requiring sharp base or gate drive pulses at crossover, that should be confined in a tight loop). jacco vermeulen: The principle is as simple and stupid as it looks: placing small signal circuits in a different plane, perpendicular to the power circuit plane, reduces induction effects. |
#14 | |
#15 | |
That you can not have parallels in different planes i already guessed. There is still a need if the boards are already separate and at distance from eachother ?
#16 |
As the distance is increased, the various high current loops tend to turn themselves into a magnetic multipole mess that nearly cancels itself. In the very near field there is not such an effect.
#17 | |
It worked for me Mauricio |
| paralleling film caps with electrolytic caps | jarthel | Power Supplies | 381 | 10th March 2012 08:13 AM |
| Large caps | Stuart Easson | Swap Meet | 26 | 25th March 2009 03:57 AM |
| Large Caps - Any good? | jkeny | Parts | 5 | 12th August 2008 08:02 PM |
| Large CG Caps For Sale | Coulomb | Swap Meet | 20 | 10th April 2006 01:53 AM |
| Is it OK to add a large bank of caps outside the amp? | mattjk | Solid State | 4 | 15th November 2004 03:18 PM |
| Page generated in 0.09619 seconds (78.59% PHP - 21.41% MySQL) with 11 queries |
