CLC design for LM317 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 11th October 2005, 08:36 PM   #1
Botch is offline Botch  Switzerland
Default CLC design for LM317
I need some help with a LM317 supply I going to build. Actually 2 supplies but want to use the same basic design for both. Originally I was going to use a CRC circuit in the supply but have been looking into using a CLC instead.
The idea is as follow:
- AC in
- RC shunt
- DC rectifier
- CLC
- LM317
- C
- nice clean DC out
The load is going to be ~400ma/24V for one supply and ~50ma/9V for the other.
I'm just having some problem deciding what is the approriate value I should be using for the Inductor in the CLC filter (mH & dc R values). For the caps I'm looking at a 2200uF, the inductor and then 2x1000uF (2000uF in total) after it. These values are adjustable of course and can go up or down (within reason).
I'm also unsure about the resonant frequency and type of inductor (Axial, Asymmetrical, Symmetrical etc) I should be using. I want to use a pcb mount so size is important.
Can anyone give me some ideas here? Or recommend a site with some design info?
Another question is what max current rating for the inductor should I look at? The LM317 can provide upto 1.5A, I'm looking at a load of under 500ma during operation. I'm thinking 2A to be on the safe side but...
I have been making some plots in Duncan PSU designer II so have been guessing some values but would like to get some ideas from other who may have been here before.
Botch...
Old 12th October 2005, 03:57 PM   #2
just registering an interest so that I can also benefit from the replies.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th October 2005, 07:59 PM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Whaddya need the choke for? Low on headroom and need to conserve voltage, while keeping peak transformer current low?
Any three-terminal regulator is already better on PSRR than you could ever hope so it can't be noise you're concerned about.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
help LM317/337 Slow-on design. Garbz Solid State 12 5th June 2013 02:36 PM
Lm317 Reg geowhitt Parts 2 30th August 2008 08:39 AM
Lm317 jlm Power Supplies 9 2nd February 2006 07:31 PM
Vin MAX for LM317 ZERS Digital Source 4 17th January 2005 02:07 PM
LM317 getting hot! DieterD Everything Else 23 9th April 2002 09:57 AM
Copyright 1999-2017 diyAudio
