AC to DC converter with selectable voltages?
I guess it was stupid of me to post his in loudspeakers section so I moved it here
I need a AC to DC converter for testing transformers for my ribbons... but I can't seem to find one with selectable voltages...
I need a power supply that will let me run voltages from 0.01mv to 4v while caring a high amperage... say something like 30 amps at 4 volts minimum with the amperage increasing as you go down to 0.01mv
I guess this is a 120w PSU minimum... a 800w one would do my purposes better though
if there's some kind of circuit I can build to do this with a normal transformer let me know
thanks
Administrator
Joined 2004
Hi Audiophilenoob,
I'm lost. Transformers accept AC and don't like DC current. Same goes for transducers, something that goes down to DC would give you "wind".
Do you want a high current AC source. If so, a Krell amp might work. The big ones can melt the odd Looney (a coin).
-Chris
this is very simple example of a regulator (dont use that schematic :D)
to the + u put the desired output voltage , thats the voltage thats gonna be on the load .
the transistor should be very high power in your case , for more then 30A current u must use something like 5 or more high current transistors in paralel , also ,use two or more driver transistors after the op amp ...
also , i dont know exactly what u are trying to do , do u wanna adjust the voltage on the load, or the current?
also , i dont know exacrl what u are trying to do , do u wanna adjust the voltage on the load, or the current?
preferably both voltage and current... where when you decrease vcltage current increases etc... it's like a regulated 500w PSU but you can change the voltages manually
lemme see what I can come up with.... if you have any suggestions on a unit I could modify etc that can already do thist that woudl be way better
darkfenriz said:
DC Voltage as low as 1mV and of course 0.01mV is a bit unrealistic unless you want to use paralleled electrochemical cells or have efficiency of a fraction of 1%. The weak point is a rectifier.
true , with currents that high u will have more then 1V on the wires connecting the load , thats why i think he needs a current regulator , not voltage
for the design I would say it's necessary to have that low mv ability
what about 0.001v? I think this is acceptable as the low point
I need it to be selectable... because I need to find the exact voltages this works within
Hmmm...
another possibility of pseudo-DC voltage this low and adjustable and high current and so on is to build a microprocessor controlled PWM supply (switching between GND and 5V) with high speed, good low pass filter and low Rdson of mosfets. Not to mention good regulation of 5V and high slew, low dead times ...
But this option seems only realistic to me.
I somewhat see what you're getting at with this design... but can you go into more detail about the multiprocessor
Also realistically I think I can cut this down to less than 5A... of needed current after talking with someone about it
this solution will require me to build two psu's eventually once I locate the optimal voltage... I need the selectability to find it though
worst case scenario 3A as the minimum amperage
thanks for the help
peranders said:
I think you may get better advices if you explain your test setup better. What is DC transformer? 30 A? 0.01 mV? 800 W? I don't understand a thing what you are up to. The post you hint that a normal 3 A lab power supply will do?
sry
what I'm trying to do is create a PSU that will allow me to turn a knob... or something can control the output voltages
between 1mv and 4V
the amperage should also increase as you decrease in voltage (same total wattage I guess)...
I originally was looking for a 800 w PSU... but since this is just for testing... I think that I can do low amperage... say around 5A or so at 1mv... and I guess w/e I can get at 4v...
I need to test a theory... but don't know the voltage I need to supply (it's voltage that matters not current) the current was just to make it easier to tell...
selectable PSU from 1mv-4v with as high an amperage as I can get... but at least 3A ... 5A would be better....... if possible if i could make it turn in 1mv incriments that would be best.. but I'm unsure of the practicality
Administrator
Joined 2004
I'm trying to figure out what you are trying to accomplish. I can't even begin to suggest anything to help you with this much information.
What I have so far is you need a DC supply at high current with mV precision. Tall order because the noise may be more than 1mV at higher currents. Tempco and connection resistance in the mV region become important, as does thermocouple potentials.
You may possibly be beyond a primary laboratory's ability to quantify the measurement.
-Chris
