12 volt battery voltage step up
Old 1st October 2005, 09:46 PM   #1
ThSpeakerDude88 is offline ThSpeakerDude88  United States
Send a message via AIM to ThSpeakerDude88
Default 12 volt battery voltage step up
hey, I just took apart an old battery backup surge protector that's battery side wasn't working. I'm assuming it was just a fuse or some other part, as the battery still has a monsterous charge.
I got a really nice 12 volt 4ah/20hr rechargeable battery thats only a little bigger than one of those 6 volt lantern batteries. My question is how did they up the voltage in the circuit to 120 for when power goes out? Did they use a Step-up transformer?
I'd like to make a sort of inverter, kind of like what they use to up the voltage from a car battery to AC 120 for running appliances.
What I would really like to do is only up it to 32 volts @ 2 amps or 40 volts @ 1 amp so I can use this in a 50 watt guitar amp I am building. I also would like to know how to build something to charge the battery with.
So Is this possible? If so, how?
Thanks for any help!
Old 2nd October 2005, 12:09 AM   #2
bogicp is offline bogicp  Yugoslavia
bogicp's Avatar
ThSpeakerDude88,
You can use one of Switch Mode Power Supply methods, but this is off topic here. Try to visit Power Supply Design part of DIY Audio.
Best regards,
-boggy
Old 2nd October 2005, 02:56 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
or vist http://sound.westhost.com
Old 2nd October 2005, 04:08 AM   #4
mm... I didn't see any inverter circuits there..
All I need to do is convert 12 vdc @ 4 amp hrs to 40 vdc @ 1.2 amps or so.
btw, how do you convert DC to AC ?
12 volt battery voltage step upHide this!Advertise here!
Purpose of 9-Volt Battery in Pearl? rgheck Pass Labs 1 13th January 2007 07:04 PM
sla 12 volt battery for Chralize question scott_m Class D 8 15th December 2005 10:18 AM
9 volt battery becomes warm chazswanson Everything Else 1 2nd July 2005 08:26 AM
48 volt battery charger DPW666 Solid State 20 11th August 2003 05:01 AM
Copyright ©1999-2017 diyAudio
