I am try to figure out how I can run my recently obtained 3 watt lumiled. I would like to run the led off of 4 AA NiMH batteries but depending on voltage/current limiting IC that might change. I was orginally just going to build a 555 timer PWM circuit to do my voltage reduction from around 5 voltage to the nessary 3.7 or so...but after doing some reading I found instead of regulation by voltage i should be looking at current regulation. I found some very easy strait forward pre built units but I can't pull my self to spend $20 Is there a cheap and efffecient way to do current regulation at 700 ma? Can i configure a 555 timer PWM circuit to use current as it's variable?
Unit thats 20 bucks but does exacly what i need
The man is out |
#2 |
you could try this............
http://sound.westhost.com/appnotes/an003.htm I have used it to drive an array of twelve 5mm LED's in parallel. works wonderfully. |
#3 |
That circuit could be easily improved by employing a standard LM393 comparator with hysteresis to sense turn-on and turn-off current, thus allowing for a very low voltage drop in the sense resistor. The other comparator of the dual package may be used for under voltage lockout. Finally, I would connect a CD4049 buffer to the output of the current comparator and I would use it to drive a standard IRF540 switch in order to maximize efficiency (maybe a logic gated one for <6V operation).
Still three active devices, standard components and very low-cost
| L-pad attenuator for midrange driver 6 1/4 inch driver | rhythmdiy | Multi-Way | 0 | 4th November 2007 03:32 PM |
| FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) | theAnonymous1 | Swap Meet | 0 | 24th April 2007 12:09 AM |
| Is 100 watt amp big enough for this driver? | oddjob7 | Subwoofers | 15 | 2nd March 2006 07:50 PM |
| Driver/ driver configuration improve soundstage width | andy2 | Multi-Way | 6 | 16th June 2005 08:47 PM |
| mtm versus tm driver recommendations on project with $500 driver and xo part limit | gsattler | Multi-Way | 4 | 20th May 2002 05:54 PM |
