Simple Low Power Voltage Regulator - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd September 2005, 03:29 PM   #11
lgreen is offline lgreen  United States
lgreen's Avatar
Originally posted by rjm
Can we build a credible regulator from, say, 8 parts and $5?
-rjm
I agree with jackinnj, the Linear Technologies regulators have superior specifications, at least as to noise, i've been using those tiny surface mount devices for over a year in various projects like for the buffer/driver in my
Gainclone. Circuit is on that page or here, but it is very similar to the LM317 circ in terms of the parts to use.
Old 26th September 2005, 05:15 AM   #12
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
I've been comparing the datasheets (always a bad idea...) of the LM340 (LM78Mxx) and LM317. The output impedance and ripple rejection curves vs. frequency are, with Cadj on the LM317 omitted, essentially the same.
So is the main performance advantage of the LM317 simply due to its optional bypass cap, or is there something I'm missing?
-rjm
Old 26th September 2005, 10:49 AM   #13
jackinnj's Avatar
btw, i found that the LTC low noise regulators behaved better with tantalums than aluminum electrolytics -- could just have been my layout.
Old 26th September 2005, 11:26 AM   #14
Did it Himself
richie00boy's Avatar
Adding 10uF as Cadj improves the LM317 response dramatically.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 26th September 2005, 12:13 PM   #15
Richard Murdey
rjm's Avatar
Yes, yes... but is that all there is to it, Cadj?
Or could it be that its not the ripple rejection, but the intrinsic output noise that's important?
/R
Old 26th September 2005, 12:48 PM   #16
Did it Himself
Pretty much just Cadj. The noise level of the 317 is lower than the 78 series, so IMO using it and adding Cadj are no brainers.
Old 26th September 2005, 03:07 PM   #17
jan.didden's Avatar
[snip]The super-reg is about two dozen parts. The LM317 is four.
So to with regards to Jan's suggestion that I use a small signal pass transistor: yes, I'm receptive to the idea, but can it be done without the trappings of the zener, the LED, all the extra passive components found in the super reg.?
-rjm
rjm,
This being DIY, I am little surprised that the # of parts (cheap ones at that) is so important to you. Maybe you want to limit board area, I can also understand that. But, what you could do is to use an integrated current source diode or a suitable jfet current source instead of the LED and transistor current source. That is only one part, but it might be as expensive as the LEd etc.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 28th September 2005, 03:41 PM   #18
Richard Murdey
rjm's Avatar
Jan,
I'm interested in providing separate regulation for each op-amp, which necessitates a total of eight units. Board area is, if I keep them on the main PCB, extremely limited... although a daughterboard is an option.
I could of course drop the condition of individual regulation, and its an open question whether two Superregs beats eight 3-terminal ICs. However, for the purposes of this thread, I wanted to restrict the discussion to solutions which were not too much more complicated than an LM317. i.e. an opamp and voltage reference, for example, possibly with a pass transistor... just to see if anything useful along those lines presented itself.
I am, as you might guess, now thinking I should just stick with the LM317...
/Richard
Old 28th September 2005, 03:48 PM   #19
Electrons are yellow and more is better!
peranders's Avatar
I think noone can tell you the right answer, you'll have to test this by yourself.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Simple regulator upgrade eradoncic Solid State 3 3rd October 2006 10:18 AM
PSU with Simple Source Follower Regulator Onvinyl Power Supplies 33 2nd February 2006 03:57 PM
Modifying this simple regulator Kevinbd Power Supplies 4 18th December 2005 07:10 PM
Simple Cascoded Regulator annex666 Solid State 30 29th March 2004 06:24 AM
Anyone used a Power opamp as a voltage regulator ? Shoog Chip Amps 12 25th October 2003 11:59 PM
Copyright ©1999-2017 diyAudio
