is 2x12v same as 24v
Old 20th September 2005, 10:09 PM   #1
Nordic is offline Nordic  South Africa
Nordic's Avatar
Default is 2x12v same as 24v
I asked for a 24V transformer but got one with 2 12V secondaries... i.e 2 poles each marked 0v and 12v...
Can I connect the 2 0v tabs to make a 24V transformer
Wil this give me a +24 and -24 rail (desregard rectification?)
Old 20th September 2005, 11:20 PM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Two 12V AC windings connected in series with the right polarity will produce 24V AC (0V otherwise), but those 24V AC won't produce 24V DC when rectifified, they will produce almost 33V to 38V DC without load (1.4 or 1.5 times the AC voltage).
Old 20th September 2005, 11:45 PM   #3
Nordic's Avatar
aiming for about 36V on + and on - rail, is this what I'll get?
Old 20th September 2005, 11:51 PM   #4
bobo1on1 is offline bobo1on1  Netherlands
No, you will get a single 33 volt supply or a 16,5 volt symmetrical supply.
Old 20th September 2005, 11:55 PM   #5
Nordic's Avatar
Thanks will exchange the unit tommorw, seems like too little juice for my gainclone then...
Old 21st September 2005, 09:53 AM   #6
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
2 x 18 to 2 x 24 V AC are normal voltages for a Gainclone. If you use LM3886 2 x 28 V AC is max.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 53 pcb's in interest so far.
Old 21st September 2005, 10:16 AM   #7
12 Cents is offline 12 Cents  Germany
12 Cents's Avatar
But don't drive 4 Ohm speakers to full throttle with this
Old 21st September 2005, 10:28 AM   #8
Nordic's Avatar
Many thanks, the company offered me a refund, but now I will have to wait for transformers to be wound for me... I so wanted to hear what the amp would sound like today
Must also still source .1ufd 50v polyprop capacitors or can I use other types?
Old 21st September 2005, 10:56 AM   #9
12 Cents's Avatar
Of course you can use other types >= 50V (ceramic, film -- for decoupling?). I'm still not sure about this. Maybe a good 'lytic of 10µ..3000µ does the job, but check for oscillations. 0µ1 in addition is safer, but maybe sonically more difficult??
is 2x12v same as 24vHide this!Advertise here!
Resources saved on this page: MySQL 17.65%
Copyright ©1999-2017 diyAudio
