I need more volts in my car.
Old 19th September 2005, 07:26 PM   #1
Dan2 is offline Dan2  South Africa
Default I need more volts in my car.
Hi guys.
i am very new to this site site - and i'm a complete amateur at electronics - most of the stuff i know i have learn't by myself!!
Anyway, here's my problem - i have a house amp in my room that im not using and i want to use it in my car. it uses a single 50v transformer. can anyone help me to build somthing to get the 50v i need from a 12v car battery??
Old 19th September 2005, 07:28 PM   #2
Magura is offline Magura  Denmark
Magura's Avatar
3 extra batteries
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 19th September 2005, 09:11 PM   #3
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
You can scale up those 12V from the car with a relatively simple SMPS. That topic has been already discussed several times, and several people have built their own PSUs. There are a lot of posts with explanations, just use the search engine.
Old 23rd September 2005, 04:48 PM   #4
sndscientist is offline sndscientist  United States
Send a message via ICQ to sndscientist Send a message via AIM to sndscientist Send a message via MSN to sndscientist Send a message via Yahoo to sndscientist
you have alot of different options, alot of it depends on your financial situation.
for example you can buy a 750 watt vector power inverter (only said a brand name cause they seem to be the most durable with inductive loads) for about $100 <usd>. however if the amplifier in question requires a sine wave such as the qsc powerlight series and the older model carvers, then simple inverters and smps may pose a problem.
depending on the vehicle in question a modification to the alternator may be an option. in my 85 ford E150 the voltage regulator and alternator were modified to produce between 90 and 110 vac 3 phase. that is an option but with that you need a high current recitfier and shunt regulator to limit the voltage to the charging system of the car.
if you choose to attempt to build something yourself and you amplifier doesn't require a sine wave and isn't really frequency dependant. such as if the transformer just dumps into a bridge recitfier and a few giant storage caps, your possabilities are almost endless.
just out of curiosity what are the rail voltages of the output section? does the rest of the amp just reduce the rail voltages to other usable levels or are there more windings and other taps on the transformer?
Adrian
Old 23rd September 2005, 09:35 PM   #5
Well. like i said i'm an ameteur, so i'd rather not mess around with the altenater. the amp i want to use is pretty old (actually REALLY old). It just has a 50v dc input, bass, treble, volume control and the speaker output. there used to be two amps connected to the one transformer, but the one blew so im just using the remaining one. i want to use this amp cos it would be really easy to install if i just sort out the power supply.
Old 24th September 2005, 08:05 AM   #6
Dark Harroth is offline Dark Harroth  Estonia
That is a little bit contradictory, if you ask me.
You said, that you had a mains-transformer for the amp. Just buy a suitable alternator and connect it with the transformer. It's many times simpler, than building a smps of your own.
Old 25th September 2005, 04:09 PM   #7
IMO, building a smps, while being a better learning experience, would prove much harder than doing a simple alternator modification or adding a power inverter. however for todays newer and more complicated vehicles i suppose alternator modifications are pretty difficult.
Old 25th September 2005, 04:23 PM   #8
anatech is offline anatech  Canada
anatech's Avatar
I don't suppose you'd consider buying a car amp (with two working channels)? It might be less expensive at the end of the day.
-Chris
Old 26th September 2005, 08:52 PM   #9
Well i have a few car amps, but they only push out 17 watts per channel, and they're not brigable. If i could bridge them, there might just be enough power - so can i build a bridge circuit quite easily or not??
I'm not interested in buying a power inverter cause it costs about the same as a car amp!!!
Thanks guys
Old 26th September 2005, 09:05 PM   #10
anatech's Avatar
Do your car amps have a transformer inside them? If they are small with chips against the heatsink, they may already be bridged. Both speaker leads would have signal, and may be 6~7 VDC above ground.
-Chris
I need more volts in my car.Hide this!Advertise here!
dc volts mike dodd Chip Amps 13 10th August 2009 03:45 AM
12 volts to 6 Dan2 Car Audio 36 23rd November 2007 06:35 AM
power transformers 220 volts to 110 volts garydmd Chip Amps 3 7th April 2007 02:52 PM
TOO many volts ????!!!! cbutterworth Tubes / Valves 6 16th December 2006 10:50 PM
Gainclone is on 120 volts will it be fine at 220 volts? Jimmy154 Chip Amps 7 29th June 2005 12:10 AM
Copyright ©1999-2017 diyAudio
