Hi.
One Japanese biggest kit supplyer, his namae is Fujiwara, told that he would make power supply unit kit next time. We can view the shematic from his BBS. http://bbs.infoseek.co.jp/Board02?user=h_fujiwara_1995 and this is final version he announced. http://easy-audio-kit.hp.infoseek.co.jp/temp/image6.jpg http://easy-audio-kit.hp.infoseek.co.jp/temp/image8.jpg From his comment. [the following is not my idea, my knowledge, but just translation] JP is option that user can add coil. C9,C10,C11,C12 should not put low-ESR cap. And he also said that this circuit was not inferior to Jung Super regulator. He cleared a problem of circuit stability with IC making reference Voltage, which Jung cleared with LM317 pre regulator. He mentioned to problem of Jung's regulator that Voltage from Zener is noisy . So his circuit has more clear reference volt with zener-less. Considering whole elements, He said that His regulator was little better. And jung's regulator and his have same problem with high frequency noise rejection. The problem is how to remove high frequency noise. He said that his circuit can add Jung's some (complicated) ideas. Jung's regulator would get any idea from his regulator ? Are ther any uncomplicated idea from Jung's to Fujiwara's? |
#2 |
Electrons are yellow and more is better!
I'll guess your japanse friend has misunderstood som things about the Jung Regulator.
The presented solution is not bad but some properties can be made better, i.e PSRR. 1 If the reference is at the regulated side the reference will be fed by a very stable voltage. 2 If the opamp is fed from the regulated side it will sence noise from the unregulated side. 3 If the series transistor is fed from a class A stage it will increase the speed of the output stage. 4 A preregulator LM317/337) will increase the PSRR even further (it was the real purpose for it!) You said "too noisy", the Jung regulator is extermely low noise so can you explain what "too noisy" is compared to what?
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#3 |
Thank you for your reply.
I think we can compare the noise of the reference with zener and without zener. He may think the reference without zener is very important. Can Jung Super Regulator get reference voltage from IC like he did with TL431 ? He recognized the validity of Pre-regulator, but he also said this approach would complicate average DIYers. If there ware simple, but great PSRR and low noise regulator. |
#4 |
A super regulator can use various types of references, TL431 is of them, other examples may be ADR42x from Analog Devices, LM329 is good and there are many more.
Was your first post more like a statement or was some questions involved? :scatch: In order to get a Super Regulator to be "super" you must use a fast opamp, but not too fast, a wideband output stage and on top of this a good pcb layout. What your friend has designed now is a "Sulzer" regulator which has been around many decades now. http://www.google.com/search?q=sulzer+regulator
#5 | |||
Is this the newest moded version ? Quote:
I know fast opeamps and also ultra-fast opeamps, but I don't know which one is enogh fast or too fast. Quote:
Thanks alot. Your replies are really helpful for me. If you would not mind my personal questions, I'm happy. |
#6 | |
The layout and PCB are a major factor, just swapping refs and opamps but using a less well optimised PCB is again a giant step backwards. Sometimes we should accept the fact that modding without fully understanding what you do is very likely making things worse. A single wrong ground wire may increase Zout and output noise 10 to 100 times easily, without the modder having the slightest idea. I know this is a sensitive point, but this is how it is. Do you think people like Walt Jung are stupid? Do you think people like him work for a year on a circuit and then somebody comes along, plugs in another opamp and presto! there's an improvement? You got to be kidding! Do you know how many opamps have been tried, measured, discarded in the long design process? I can go on and on, and I am sure P-A you understand all this, my talk is more addressed to the original poster. Your friend has no idea what he is talking about. Jan Didden
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
#7 | |
Old Colony Sound (which is the storefront for AudioXpress) still carries boards for the 1995 regulators. These can be updated to the most recent version. http://www.audioxpress.com/bksprods/...cuitsbuild.htm Susbcribing to AudioXpress is very worthwhile, for just tthe reason that they keep a thread going for decades ... I am sure folks remember the first articles by Nelson Pass.., but what the heck, I am a magazine junkie and also subscribe to Elektor, Wireless World, QST, QEX, Nuts N Volts, Circuit Cellar as well as a bunch of trade magazines. There is always some "black magic" in analog design. |
#8 |
Here are lot's of info
http://www.google.com/search?q=walt+...uper+regulator and of course Walt's own website http://home.comcast.net/~walt-jung/w...7s-20PDFs.html Here at diyaudio. super regulator http://www.diyaudio.com/forums/searc...der=descending super regulator jung http://www.diyaudio.com/forums/searc...der=descending Using D44H11 or BD139 (100 MHz transistors) I'll guess the limit of the opamp is very near the AD825 and AD817. Many slower types will work fine like the OPA134. The only thing you must consider is min voltage and common mode limts. If you plan to have 5 volts out you must choose a 5 volts compatible aopamp. I have heard one using some faster type 145 V/us THS4601(?) from Texas but I'm not really sure how good it actually worked. http://www4.head-fi.org/forums/showt...highlight=jung
#9 |
I'm the one using a ths4601, P-A is wrong, the slew rate is 100V/uSec
http://focus.ti.com/docs/prod/folder...t/ths4601.html seems to be working fine to me. |
#10 | |
regulator , approx. 0.25 ohms vs. microohms for the super regulator. The speed difference was also a factor 5-10. Compare this difference and compare also the difference when you are using Silmics, Cerafine, Sanyo AX (in my case), Black Gate or whatever.
| yes, another jung regulator, i know | geekysuavo | Power Supplies | 8 | 25th September 2009 12:29 PM |
| Good alternative to AD817/825 in Jung regulator? | 5th element | Solid State | 1 | 21st April 2007 08:06 AM |
| WTB: Jung Super Regulator PCB's | vadimgal | Swap Meet | 4 | 29th May 2005 06:04 PM |
