Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd September 2005, 01:08 PM   #11
DaBit is offline DaBit  Netherlands
Send a message via ICQ to DaBit
OK, so a flyback can be done also.
I'm wondering: how much cost or space does a flyback really save when compared to a single transistor (transformer with reset winding) forward converter or push-pull?
The flyback topology uses the least number of components, but is it really cheaper or smaller? I always used postfiltering on the secondary voltages using an LC filter to reduce supply noise.
The forward converter also needs a buck inductor which can be dimensioned for the required noise levels. It also seems that it needs less capacitance on the secondary side when the buck inductor is used in continuous mode.
With push-pull and current mode control the duty-cycle can probably be increased to 80% or more (at Vin,min), which means a lower RMS current through the capacitors, and thus smaller capacitors. I also doubt that I would need post-filtering. I could also use a smaller core, if I can get anything else than ETD29. Also, switch power dissipation is split over two switching devices, reducing the amount of copper area required for cooling. The extra cost would be twice the amount of windings on the transformers (but magnet wire diameter can be lower due to recued I2R losses) and a second MOSFET or transistor.
This is not based on any math or knowledge, just ideas.
Any comments?
Intercom sound system help FerisB Everything Else 4 22nd June 2009 03:20 PM
Motorcycle intercom. Faulty POT rmim Everything Else 1 15th October 2008 09:09 PM
SMPS questions sakistsalikis Power Supplies 3 10th March 2007 12:54 AM
Motorcycle Intercom Input Mixer w/Override HiOSilver Chip Amps 4 30th September 2006 12:19 PM
SMPS questions gaplessophile Chip Amps 5 4th April 2006 02:41 PM
Page generated in 0.07692 seconds (68.41% PHP - 31.59% MySQL) with 10 queries
