Assymmetric outputs in half-bridge
Old 5th September 2005, 03:30 PM   #41
Pierre is offline Pierre  France
Banned
I have been, at last, able to regulate my PSU.
The control setup is as follows:
- Secondary: two 30V zeners, 1k5 resistor and optocoupler diode in series, from + rail to - rail.
- Primary control: optocoupler phototransistor has collector to +12V (control IC supply), emitter with adj. resistor to GND (filtered with a 120nF cap as I found it very noisy)
- Internal SG3525 Error opamp configuration: Error signal is taken from phototransistor emitter, fed to the error opamp inverting input via a 10K resistor. From there, 330K resistor in parallel with 10nF, to COMP pin (inverting amplifier with gain 33).
The non-inverting input is tied to Vref (5.1V)
COMP pin has about 500nF to GND.
The supply regulates OK, but with "light" loads (light being 100W), it shows some strange periodic oscillation, about 30Hz, 4Vpp (amplitude and freq. varying as load changes).
It is as it the control was not very estable. I am also afraid that with those values its transient response will be veeery slow.
How can I find the optimum values for both (almost)no load good behaviour and adequate transient response?
The supply is running at 40KHz by the moment. Max power I have tested is 450W for several seconds.
Best regards,
Pierre
Old 6th September 2005, 08:40 PM   #42
e96mlo is offline e96mlo  Sweden
Won't you get the tolerances of the zeners on the "wrong side" of the regulation this way?
Your error amp will never know if it is regulating a zener missbehaviour or the correct output voltage.
Old 7th September 2005, 07:13 AM   #43
Banned
Well, of course, from unit to unit there would be an error due to zener tolerances, but once it is adjusted (there is a potentiometer), the output should be reasonably estable (without having into account temperature effects on the zeners, optocoupler and references, of course).
But that should be more than enough, anyway.
The problem is that it tends to "oscillate", and I have found that not only at light loads. What changes with load is the frequency of that oscillation. Its amplitude is around 4Vpp.
Best regards
Old 7th September 2005, 01:05 PM   #44
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Why don't you wire the error amp in the way I told you? That 120nF capacitor is ruining stability, there must be only a single LF pole provided by the output filter and compensated by a zero in the error amplifier, and the optocoupler is probably too slow to keep the required phase margin at high frequencies when compensation is not applied in the photodiode side.
Old 8th September 2005, 05:55 AM   #45
Banned
Thanks for the comments.
Sorry Eva, what was your suggestion: using an external opamp and keep the SG3525 internal error amplifier as a non-inverting unity gain buffer?
I added the 120nF capacitor at the start, in open loop (when I regulated the output by means of a potentiometer), because when I observed the emitter waveform it was pulsing at the switching frequency, when I expected DC (with noise) with estable dummy load and input voltage, so I added it as a lowpass filter.
Now it comes to my mind that perhaps it was due to noise pickup by the scope probes...
I will try to remove it and see what happens.
Given that my LC filter is 47uH + 6600uF per rail, what freq. should I place a zero in my fb loop at?
Thanks!
Old 27th September 2005, 06:48 AM   #46
Banned
After a little more experimenting, I have decided to follow Eva's advice and add an external opamp for the error amplifier.
My PSU regulates about ok, but there is a low frequency ripple (around 5-6Vpp) with low loads, which produces a very audible sound on the amplifier. I guess it is not estable.
Please tell me if the following sch is a good starting point. The error amp must be compensated, but first let's concentrate on the DC configuration:
thanks!!!
Assymmetric outputs in half-bridgeHide this!Advertise here!
Full Bridge X Half Bridge: What's The Best? CHACALPOWERS Power Supplies 8 18th July 2008 04:45 PM
Half Bridge Reference maverick_123 Class D 0 7th December 2007 02:06 AM
half-bridge VS. full-bridge gearheadgene Class D 3 25th May 2007 08:49 PM
The difference of Push-pull,Half-bridge,Full-bridge digi01 Chip Amps 0 8th September 2006 02:10 AM
Whats the difference between full bridge and half-bridge SMPS ? skaara Class D 6 3rd February 2005 07:23 PM
