Powering Crazy Car Setup In Bedroom
Old 5th September 2005, 09:40 AM   #101
JohnnyJ is offline JohnnyJ  Australia
Send a message via ICQ to JohnnyJ Send a message via MSN to JohnnyJ
Originally posted by Tweeker
Yes, there are home subs that can put out mad bass, a question though, how much volume (liters/cu feet) can you use?
The Peavy is pro audio gear, they dont care about low bass, its low frequency response stops @50hz. What is meant by program is something along these lines:
These are 4 ohm speakers, and they can take almost 100V rms. This =~2400 watts. 100V rms means 200V peaks. This =~4800 watts. So youve got your 2400 watt amp cranked up all the way, but your playing music. The average power of music : peak is typically around 10:1, but is lower with more dynamic compression. This is pro gear its built with some margin. Somewhere I read 3:1 but Im not at all sure about that.
I just remembered that you said that earlier on... what PRE-MADE equipment can I buy that will give me the bass vibration I am after?
... I am so confused I don't go know what to do or where to go next.
Old 5th September 2005, 10:23 AM   #102
Tweeker is offline Tweeker  United States
Guru is reaally stretching it for me. The driver is simply refering to the actual woofer (or tweeter or whatever the case may be). PE claims a pair of LAB12s in horns= 6-8 18"s.
Extremely crude analogy- think of a bicycle horn except you have a woofer in a chamber instead of a squeeze bulb.
Ignore the dots w a woofer, the space in the compression chamber as the air is compressed it gives something for the woofer to work against, it "loads" the woofer. There are lots of variations, this is just to give an idea.
_\.../__
|. W..|
|____|
Old 5th September 2005, 10:40 AM   #103
1 Behringer Europower 2500 is plenty, this is a bedroom, not a large nightclub.
Folded sonotube TL my easy enclosure suggestion.
Scale up for 15" driver with a 16" and 22" tube.
A thread on the subwoofer forum might be a good idea. I have Ascendant drivers, but they arent currently available, niether area Adire. TC Sounds might be good.
The LAB12s go much lower than the Peavy, and louder, but lotsa carpentry.
Old 5th September 2005, 12:53 PM   #104
But 2 would be better, and 3 even better than 2, right? I mean you can't really say no because it's pretty obvious, but I would go with at least 2.
Okay well low "clean, powerful and smooth" bass is what I am after, and working with this budget, I really don't know what to do. I don't have the skills to make the enclosure[s] for that LAB12 horn.. I would have to pay someone to make it for me and it seems like a huge mission.
What are some of the most powerful and AFFORDABLE PA subs around? Boxed or unboxed doesn't matter to me..
Old 5th September 2005, 01:43 PM   #105
Alas, two probably wont be better on your budget. Also, you have to consider your house wiring going with more.
Old 5th September 2005, 01:44 PM   #106
Alright.
So do you have ICQ or MSN dude?
It would really help me so much and go way quicker..
MY MSN IS a_bikerz_rush@hotmail.com
Cheers!
Old 5th September 2005, 01:50 PM   #107
Tooncescatdrive is my AIM/ICQ ID
Old 5th September 2005, 01:56 PM   #108
forgot my ICQ pw. Just installed again haven't used for a long time.
Will add you now!
Chur
Old 5th September 2005, 02:09 PM   #109
I'm having some trouble getting my ICQ working, I will add you as soon as I get a new ICQ # - busy doing it now except having few complications.
Old 5th September 2005, 02:25 PM   #110
Heres an idea, Europower 2500 as amp, BFD for equalization, Behringer CX2310 Super X for XO.
12 $37 Pyle PLG 15s in 2 6 speaker U-frame dipole stereo line arrays. NaO system site has the enclosure details.
Powering Crazy Car Setup In BedroomHide this!Advertise here!
Subs too big for bedroom bigwill Subwoofers 27 6th October 2005 05:23 AM
Car audio in my bedroom. KoRnRULZ6 Car Audio 3 25th September 2004 10:23 PM
Speakers for bedroom 5th element Multi-Way 3 9th April 2004 10:50 AM
