Jung problems - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 21st July 2005, 12:43 PM   #11
jan.didden's Avatar
Yes, you really should measure the in/output of the opamp. Second guessing and groping around in the dark is VERY inefficient.
You're still off on Vout. Across the 890 ohms there is 6.9 V. Therefore, across the 1130 there is 1130/890 * 6.9 = 8.76 volts. Therefore, Vout = 15.66V. Since the opamp needs some volts to operate, and you also loose some in the series transistor, you need probably a minimum of 20VDC input under load. Please check.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 21st July 2005, 12:50 PM   #12
jackinnj's Avatar
Jan Didden
you also lose across the LM317 pre-regulator -- (the version which I built did not incorporate this.)
Old 21st July 2005, 02:25 PM   #13
rhymeswthorange's Avatar
As for the Vout, switch the two resistor values you're using and you'll get my 12.33V. Across the 1130 ohms there is 6.9 V. Therefore, across the 890 there is 890/1130 * 6.9 = 5.43 volts. Therefore, Vout = 12.33V.
I'm using a 1n5235 zener to the collector of Q2.
I'll measure voltages as soon as I get home.
Thanks again for all the help!
Old 21st July 2005, 04:56 PM   #14
jan.didden's Avatar
We may still talk about different things.
I'm not using R1, R2, you are.
In the Jung schematic where there are R1 and R2, I see a 1N4148 diode, not a zener. And in that diagram, Vout = 15,66, sorry.
How many volts is that zener?
What else is different?
Can you post a diagram of the one YOU buiilt? We may catch something that went unnoticed so far.
Jan Didden
Old 21st July 2005, 05:24 PM   #15
Oh, sorry. It's the "Jung Super Regulator 2" on that site. http://tangentsoft.net/elec/bitmaps/...lator-2000.png The zener is 1N5235B, 6.8V.
Could anyone explain the variations in voltage across different loads? Thanks!
Old 22nd July 2005, 12:58 AM   #16
Pin 6 (output) has 13.5V (w/ respect to ground)on it with the 250 ohm load. There is a 4.35 difference between +In and Output.
With no load, Pin 6 has 17.9V and there is 6V between +In and Output.
The voltage difference btween +In and Ouput are the same polarity - one isn't negative.
Problems with a Jung regulator Gluca Solid State 4 19th February 2009 01:40 PM
Jung/ALW reg issues. 5th element Power Supplies 41 10th May 2007 06:09 PM
Very Low Noise 5V Jung Reg fmak Digital Source 2 15th July 2004 05:20 PM
My Jung SuperReg PCB Algar_emi Solid State 30 9th February 2004 04:07 AM
Copyright 1999-2017 diyAudio
