Q/A about power supply
Old 15th July 2005, 03:06 PM   #1
luffy is offline luffy  Singapore
Default Q/A about power supply
I was asked by my teacher to produce a schematic diagram of a triple output power supply which supply output voltages of 15v
-15v and -5 v of not more than 15 component. After looking through different electronics forums and web page i manage to come out with this diagram. I just want to ensure that the circuit in the diagram will net me my desire voltage. Thanks
(meanwhile i will be writing a report)
Old 16th July 2005, 02:33 AM   #2
As i was writing the report, question starts to surface, i was told that the diode from the negative side of the power supply should be place in the opposite direction relativeto that of the positive side. Why is this so?
Old 16th July 2005, 04:59 AM   #3
Issit becos by placing the diode in that position, when the -15v and the gnd pin is connected, current will flow from the GND pin to the external circuit and back to the -15 v pin, hence making the the voltage negative.
Q/A about power supplyHide this!Advertise here!
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Copyright ©1999-2017 diyAudio
