Parallel transformers and bridge
Old 11th July 2005, 04:00 PM   #11
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Toroids are almost allways bifilar wound, so close matching between secondaries may be assumed. Otherwise, they would tend to saturate even when operated in the usual way.
For the sake of simplicity, I would just connect in paralell the secondaries of each toroid and use each transformer to supply one rail through a diode bridge.
Also, there is a trick to further reduce PSU voltage drop and ripple in stereo LF arrangements. This is achieved by inverting the input signal of one of the channels and reversing the polarity of the load. As a conequence of that, both channels will seldom be drawing current from the same supply rail at the same time and PSU efficiency will be improved.
Old 11th July 2005, 08:04 PM   #12
Raka is offline Raka  Europe
Raka's Avatar
Buenas noches,
Eva, thanks for this good idea. I'll think about it, seems that has no drawback whatsoever.
What is beyond the speaker?
Old 12th July 2005, 08:59 PM   #13
richwalters is offline richwalters
richwalters's Avatar
Default Re: Thanks for your reply
Originally posted by Raka
The toroids I have are identical, at least they are the same RS code and were bought at the same time. So they will be more identical than different.
Does anyone has a different suggestion?
Watch out! toroids may look be identical....but could be made by different vendors using same RS label. Check off load secondary winding voltages first. If the primary has taps, DON'T parallel them. Why you might ask ? A manufacturer might round up the taps to next integer turn and with thinner wire can overheat if connected in parallel with another tranny.
There's nothing wrong in parallel operation so long the voltages are identical.
Hang on.......Mains toroid transformers are NOT wound Bifiliar.....no interwinding screen ...eh ? Manufacturer wouldn't get isolation and creepage approval. Some are wound so badly that the leakage inductance is way worse than EI types.
richj
Old 13th July 2005, 12:26 AM   #14
Eva's Avatar
Dual secondaries are wound bifilar.
Old 13th July 2005, 06:49 AM   #15
okay.....secs. .......was getting late.
richj
Old 14th July 2005, 06:23 AM   #16
Chris Jennings is offline Chris Jennings  United Kingdom
If the transformers have a orange label with either nuvotem or Telmag as a manufacture name, then the secondaries will definately be bifilar wound and you will have no problems paralleling them.
It would probably be best to use one transformer for each rail though.
Chris
Old 14th July 2005, 07:15 AM   #17
Raka's Avatar
Yes, mine are from Nuvotem, and the reference from RS is 223-8897. Will be easy now to check if for this application is best to use one single PS (with 500+500VA) or to use two separate PS (500VA each).
The amplifier power is not going to be very high, as the voltage of the transformers is just 25V, but I'm more concerned about the current delivery needed for the paralleled XLS10.
Parallel transformers and bridgeHide this!Advertise here!
Parallel Bridge? rgrayton Chip Amps 16 20th January 2009 03:50 PM
Bridge Parallel AMP myanmar Chip Amps 15 11th March 2007 09:02 AM
Bridge or Parallel? Roushon Chip Amps 71 16th September 2006 06:47 PM
Bridge/parallel calculations?? JDeV Chip Amps 5 24th January 2004 09:31 AM
parallel or bridge rulezzz Chip Amps 1 8th January 2004 06:59 PM
