1KW SMPS help needed
Old 26th September 2005, 05:43 PM   #91
Danko is offline Danko  Hungary
Eva!
What is the ground switch? That is the paralelled 4.7nF and 1MegOhm resistor between the primary GND and secondary GND ?
Best regards, Danko
Old 26th September 2005, 06:19 PM   #92
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
No, it's just a switch between earth/case and power amplifier ground.
Old 27th September 2005, 11:47 AM   #93
Ahamm, thanks!
Best regards, Danko
Old 27th September 2005, 01:12 PM   #94
Eva's Avatar
I forgot to mention that the main purpose of that switch is to allow you to break ground loops when you can't break it anywhere else.
1KW SMPS help neededHide this!Advertise here!
help needed on current control SMPS jegandren Power Supplies 18 6th October 2008 03:28 PM
Car amp smps needed kissendi Car Audio 5 28th January 2008 05:08 AM
Cheap 24v SMPS - advice needed ericallan Chip Amps 11 13th October 2005 05:43 PM
Small Car SMPS needed.. deepanger Solid State 6 10th June 2003 02:48 PM
Copyright ©1999-2017 diyAudio
