multiple secondaries on a toroid
Old 9th July 2005, 05:04 PM   #11
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
since we're on the topic on tranny VA rating, I bought a toroid used as an autotranny (rated as 1kVA but will be 500VA with isolated secondaries?) which just has two 110V windings in series, I added dual secondaries of 33VAC with #15 which is much thicker than what most 500VA's use. (I've seen most use #16?)
does that mean I could get a bit more power from that than my expected 500VA?
Old 10th July 2005, 06:18 AM   #12
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Your VA rating would probably be somewhere between 500VA and 1000VA.
Old 10th July 2005, 06:26 AM   #13
I just measured the winding resistances. I got 0.9 ohm on each 110V primary and 0.1 ohm on each 33V secondary.
I think that's good?
multiple secondaries on a toroidHide this!Advertise here!
Rectifying multiple secondaries.. DigitalJunkie Power Supplies 6 15th February 2009 03:26 AM
Multiple secondaries toroid steveline Chip Amps 29 30th August 2007 06:20 PM
winding multiple secondaries on a toroid??? Puggie Power Supplies 3 9th August 2006 05:58 PM
Multiple secondaries hook-up!!! Klimon Tubes / Valves 4 10th July 2006 02:32 PM
