Will this MOSFET-driver circuit work? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 24th June 2005, 11:16 AM   #1
Danko is offline Danko  Hungary
Question Will this MOSFET-driver circuit work?
Hello!
I have attached a schematic. Will that mosfet-driving work?
I'm designing a 35V -> 25V@5A step-down converter, with ONsemi's MC34063 IC.
Tanks in advance!
Best regards, Danko
Old 24th June 2005, 12:26 PM   #2
mflorin is offline mflorin  Romania
It never works.For driving the MOSFET you need an isolated voltage or a bootstrap circuit.
The base of the pre-driver transistor inside the MC34063 has a drive signal which is related to ground and not to the SW_E pin.
Florin
Old 24th June 2005, 12:46 PM   #3
Do I need a level shifter?
The diode "D", and the capacitor "C" isn't enough for a bootstrap-circuit?
Best regards, Danko
Old 24th June 2005, 01:52 PM   #4
OK, if we take a closer look over the push-pull driving circuit we will see that in the off state of the internal MC34063's transistor, the pnp's base is floating.So you have a lot of chances to keep the pnp off and no signal for the gate of the mosfet.
The D and C looks indeed like a level shifter circuit, but you need an alternating signal for shifting.In the present configuration you didn't have that signal.
Watch out for the maximum gate to source voltage rating.I think you need something to limit the voltage level.
Florin
Old 24th June 2005, 02:19 PM   #5
I draw somathing in TINA (this is a simulator-prg), it seems to work.
T4 transistor is the MC34063's internal transistor, and that R3 is also the integrated resistor, inside MC34063.
On the T4, there's 37V, which is quite high. Accourding to the datasheet of MC34063, the max. V_emitter_collector is 40V. I think, I gonna have to use a dedicated powersupply for the MC34063.
What do you think of this?
Best regards, Danko
Old 24th June 2005, 02:21 PM   #6
And the switch torned OFF
Best regards, Danko
Old 24th June 2005, 02:35 PM   #7
You made at least one mistake in the simulation.The emitter of internal transistor isn't conected to the ground of input voltage.It is a floating point. At least this is what I see from the first schematic.
Repeate the simulation with the circuit like you draw at first time and see if it's working.
Old 24th June 2005, 03:09 PM   #8
It's not internally connected, I connected to the gnd, the internal transistor's emitter(pin 2).
Best regards, Danko
Will this circuit work? G Tubes / Valves 21 17th February 2007 05:41 AM
813 SE circuit,will it work? Richard Ellis Tubes / Valves 6 19th November 2006 04:05 PM
How does that circuit work ? Bernhard Digital Source 0 28th April 2005 08:03 PM
Would this circuit work??? cunningham Solid State 10 31st January 2005 06:16 PM
Copyright 1999-2017 diyAudio
