Suggestions for books/articles on building a DC to DC converter
Old 9th July 2005, 03:32 PM   #11
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Default Lm2577
I just checked at National Semiconductor's website, and the LM2577S-ADJ is $3.12 USD each, or you can get FREE samples. Kinda hard to beat that price. When submitting for samples, ask for five (the max allowed). This will give you some room to work with if you're unsuccessful at the first attrempt.
The"-s" suffix means that this is a surface-mount version. Or, if you prefer to use the standard 5-pin TO-220, then ask for LM2577T-ADJ; and, of course, the-ADJ means that it is the adjustable version.
When ordering the samples, if you're an engineer for a large firm, let them know that. That way, they're likely to be more receptive than if you're putting down that you're just an experimenter. After all, these companies use their samples programs to promote their products to prosepctive customers who might buy in the thousands or millions. Hope this helps.
Steve
Old 9th July 2005, 06:42 PM   #12
N-Channel's Avatar
Default More LM2577 Stuff
Right Now, I am in the middle of building a DC-DC "uppie" and "downie" all in one circuit. It goes something like this: LM2596 (150kHz, 3A step-down chip) to give me 6V@3A for powering a camcorder, and LM2588 (100kHz-200kHz, 5A externally synchronizable boost chip) to give me 19V @ 3.5A to power a Laptop.
Obviously, the '2588 is synched from the '2596 to eliminate beat frequencies between the two. When I finish, I will post some pics with results. I have done this circuit before with outstanding results. The article on synchronization between the two chips can be found here:
http://www.national.com/an/AN/AN-1082.pdf
I realize that this might not be directly related to the topic at hand, but it might give some useful insight for doing other SMPSs to power other audio ckts.
Steve
Suggestions for books/articles on building a DC to DC converterHide this!Advertise here!
Suggestions for Building a 1x15 Cab Thraxor Multi-Way 4 10th December 2008 11:29 PM
Building a VGA -> Component converter Titan2782 Parts 1 24th April 2008 10:44 PM
Suggestions on books diesel_tech Tubes / Valves 6 26th March 2008 10:08 PM
Building First Amp, Need Help/Suggestions MotoMan_Yz400 Class D 1 7th January 2008 06:03 PM
Newbie at Building Amps/Any Decent Books Out There? barroter Everything Else 7 25th October 2003 11:39 PM
