Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th September 2005, 07:34 AM   #21
Originally posted by Disney_SK
10k resistor from pin at the edge to the one next to it.
I
sorry, not the one next to it, but INV_IN
Old 8th September 2005, 08:54 AM   #22
Pierre is offline Pierre  France
Banned
Thanks, I will try.
So you haven't found any problems with that configuration, even with very low output current? Any ripple in the output rails?
Old 8th September 2005, 09:28 AM   #23
Originally posted by Pierre
Thanks, I will try.
No, I did not.
Actually there are only two problems with my design.
1. Lots of switching noise going out of the case through holes, mains cable and input audio signal terminals, what I plan to solve by better case design (holes not longer than 2 cm), mains off-the-shelf input filter (EPCOS) and input audio signal transformers (probably JENSEN).
2. Lack of any power supply protection against overload. Switching mosfets have blown several times yet. I plan to mount small current transformer at the primary winding which (through rectifier, filter and voltage divider) will drive the input of an auxilitary op-amp which will drive the SHUTDOWN pin of the controller.
Old 8th September 2005, 10:13 AM   #24
e96mlo is offline e96mlo  Sweden
I can't read your files but if you don't have any Y1-caps between primary gnd and secondary gnd I suggest you mount a 2,2nF Y1. That will reduce common mode EMI a lot.
If you don't have a mains input with a mains earth connector you can go all the way up to 4,7nF but if you allready have Y-caps between mains and earth you must not exceed a total capacitance of 4,7nF.
Old 8th September 2005, 10:23 AM   #25
Banned
Mine don't have any filtering as well, but it is only a prototype, I will go with that after it works well. Is your switching noise perturbating the audio? (is it audible)
About protection, I added a small current sense transformer (from Coilcraft), that is then rectified and filtered, it attacks the SD pin of the SG3525 but I had to disconnect that because it triggered erratically, I have to insert an opamp or comparator before as you say.
I will keep you updated on my findings in that area.
Old 8th September 2005, 07:55 PM   #26
The amplifier itself, is not picking up interference from the supply. But the whole device is emitting lots of EMI and it interfers with other devices close to it and on the same mains phase and ground, and input terminals.
Originally I also did not plan to put an OP-AMP into the protection circuitry, but as soon as I saw that trigger voltage range (0,6-1V) for SHUTDOWN pin, I decided so.
Old 9th September 2005, 12:02 PM   #27
first, please explain what are "Y1" caps. I have directly connected primary and secondary ground. Should I break this connection and put that 2,2nF cap between?
Currently I only have two 1uF/400V capacitors at mains AC rectifier (one at the input, one at output). But soon I am going to mount Epcos 10A off-the-shelf mains filter (B84111-A-B110), so I hope this will help reducing RFI and EMI.
Old 9th September 2005, 03:04 PM   #28
Does this mean that you have no galvanic insulation between your primary and secondary side on an off-line (230/115VAC) supply?
If the answer is yes on my question above, then YES - BREAK that connection. Otherwise you could end up killing someone...
Old 9th September 2005, 04:02 PM   #29
mzzj is offline mzzj  Finland
What are you talking about? standard practice in in plenty of smps units is to have prim and secondary grounds directly connected. As a matter of fact separating them can cause extra safety risks as then transformer and everything else has to be desinged double-insulated.
Maybe you mean neutral by ground as you are talking about Y-caps? as between neutral-ground would be a right place for a Y-caps
disneyland, check this for cap explanations:
http://www.justradios.com/safetytips.html
There your can also find pic of typical EMI-filter with Y and X caps and CM-choke.
Old 9th September 2005, 04:20 PM   #30
NO. I have.
There is pretty well isolated transformer, and the case is firmly connected to mains ground terminal. On the same terminal, a connection to transformer's secondary "zero-point" is made.
Tripath recommends this (along with other anti-EMI tweaks)
As far as I know, I could ONLY kill someone if whole metal case would NOT be connected to mains ground terminal. Primary-to-secondary ground connections have nothing to do with safety.
Please correct me if I am wrong.
I took a short look at your link and also on the label on this epcos filter, and it's clear to me.
SMPS problem MaXiZ Class D 136 29th October 2012 02:03 PM
SMPS problem? choncba Car Audio 11 8th May 2008 07:54 AM
What is the problem with the K6 SMPS? ghemink Power Supplies 2 16th March 2005 02:30 AM
Rod's SMPS Problem fr0st Parts 9 15th March 2003 06:46 AM
Copyright ©1999-2013 diyAudio
