15V for opamps from 35V ?
Old 17th June 2005, 05:48 AM   #11
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
As we said is 35 V dangerously near the limit of the 78xx/79xx but as Carlos point out a series resistor may be inserted but you must know the load in order to calculate the resistor value.
The only disadvantage as I see it is more parts around the LM317/337 but in this particular case it's only one more
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 14 pcb's in interest.
Old 24th June 2005, 12:05 PM   #12
Reactance is offline Reactance  South Africa
Reactance's Avatar
Dont forget to decoupling caps near the Vin and Vout near the voltage regulators.
Cheers!
There’s nothing worse than the smell of burned output transistors!!
Old 27th June 2005, 03:18 PM   #13
sndscietist is offline sndscietist  United States
Send a message via ICQ to sndscietist Send a message via AIM to sndscietist Send a message via MSN to sndscietist Send a message via Yahoo to sndscietist
granted i'm still just the new guy here, i have a little insight to this problem. i have been repairing Peavey amplifiers for a little over 3 years now. i'll use the CS series as an example their rails are aprox +/- 59 VDC it's split like this, the output gets the full +/- 59 then there is a series resistor the next stage goes to the driver board for the driver output transistors. they drop the voltage a little more then there is another resistor to drop it to the final range. (looking at the schematic now) for their needs they use a 10 watt 10 ohm and then a 5 watt 1k. but case and point series voltage dividers are probably the safest and cheapest way to go
Old 27th June 2005, 10:19 PM   #14
jackinnj is offline jackinnj  United States
jackinnj's Avatar
You can use an 80V transistor and a zener diode to make a power-zener.
Old 28th June 2005, 08:05 PM   #15
sbrads is offline sbrads  United Kingdom
A few years ago I modified a Crimson Elektrik moving coil head amp's 15v power rails. I tried a zener + transistor (noisy), 7815's (extremely noisy) and ended up with LM317's fed from 50v via a dropper resistor plus filter caps as by far the quietest and simplest supply. Any hiss from the regulator got straight through the discrete mc circuit and was very audible, and decoupling caps across 7815's doesn't do a thing to reduce it either. LM317's are the way to go.
Old 28th June 2005, 09:14 PM   #16
now correct me if i'm wrong but don't LM317's use the same PWM style as 78xx series regulators. which means they should have the same harmonic output at X voltage. it was my understanding that the only difference with the 317's was that they were variable. and that much like triacs they only varied the pulse width.
like i have said before i could be way way off but that was what i always thought
Adrian
Old 28th June 2005, 10:07 PM   #17
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
The 317 and 78xx are linear regulators. Any triangular hash at their output is simply due to the feedback scheme employed. The 317 is a totally different beast to the 78xx and this is reflected in the performance.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 28th June 2005, 10:16 PM   #18
kevinkr's Avatar
Take a look at Linear Technology's line of linear regulators, they have much lower noise than the venerable 317/337, tighter regulation and lower output impedance as well.. Try LT1086 and LT1185..
Kevin
15V for opamps from 35V ?Hide this!Advertise here!
FS: Opamps Charlez Swap Meet 2 17th August 2008 11:45 AM
Opamps and Vca's impsick Vendor's Bazaar 5 2nd August 2007 11:48 PM
OPamps xaudiox Swap Meet 2 31st August 2006 03:40 AM
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 11:07 PM
Opamps seiko_citizen Swap Meet 7 3rd May 2005 04:09 PM
