I am planning to power up my system with a nice set of 30A relays that will be rigged to go off one after the other. The coils are 120v and will be driven from an Isolation transformer such that each end of the coil will see 60vac and not 120v plus 0v.
Question, what should I use to contain the back EMF from teh Coil as it is turned off? I am planning a 1A diode in series with a 300ohm resistor, any ideas on the values of the Back EMF containment for a 120vac coil? See pic: Thanks! |
#2 | |
Hi, AC driven relay doesn't need any back EMF suppression, IMHO. However, using snubber RC might be a good idea. Regards, Milan |
#3 |
Thanks for your input, What values do you suggest?
#4 |
#5 |
Thanks JC,
In my case the Relays will be housed in a separate Enclosure ala the Adcom ACE 515. But point well taken, thanks! |
| FS: Large inductors, Large Ports, and Leaky Holes | luvdunhill | Swap Meet | 10 | 6th March 2009 03:01 PM |
| Single coil latching relay control?? | cal34 | Parts | 0 | 15th February 2009 08:33 PM |
| Back to Back transformers and safety ground | dsavitsk | Tubes / Valves | 1 | 9th February 2009 10:10 PM |
| relay coil on ESP's project- bd139 equiv? | ThSpeakerDude88 | Car Audio | 9 | 23rd January 2007 03:24 PM |
| (Attn Planet 10!) active xo & 2.5 way back to back Vifa P13 mids - questions | paulspencer | Multi-Way | 9 | 15th August 2004 05:34 AM |
| Page generated in 0.08246 seconds (68.61% PHP - 31.39% MySQL) with 11 queries |
