Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th May 2005, 07:44 PM   #11
AndrewT is online now AndrewT  Scotland
Instead of unwinding the whole secondary windings just break into each of the secondaries and create a 17 0, 0 17, 17 0, 0 17.
You can see where the tappings come out from the core.
The midpoint of the windings will be about diametrically opposite.
Unwrap the outer insulation to expose the secondaries. Scrape a little enamel from a two adjacent secondary wires and find which one connects to which ends.
CAREFULLY power up the transformer and measure the voltage at the two exposed patches on the windings. If these voltages are well away from the midpoints try to work out which direction to move around and try again ( with the power off). If you do go wrong here a little varnish & new insulation wrap will save the tranny.
Once you have found the winding midpoits cut the two windings at these points and unwind the extra turns to achieve your desired voltage. You will probably only have to remove a maximum of 2 or 3 turns. Solder in some new flexible wires to the 4 new ends to create a 4 secondary output from your tranny. Insulate it with black insulating tape using a 55% overlap on the turns, self amalgamating would be better but quite difficult to get off later.
You now have a choice; parallel two windings to double the amp capacity or create a close approach to dual mono.
good luck.
regards Andrew T.
Old 13th May 2005, 12:00 AM   #12
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
I'm just going to sell them..
voltage regulator Sebastiaan Power Supplies 2 12th June 2005 07:51 PM
Voltage Regulator zoro72 Everything Else 0 26th April 2004 05:30 PM
Voltage regulator annex666 Solid State 1 27th August 2003 02:50 PM
Voltage regulator help! kasra Solid State 7 23rd November 2002 02:07 PM
What voltage regulator to use? Thomas Everything Else 2 28th September 2001 02:53 PM
Page generated in 0.07023 seconds (62.92% PHP - 37.08% MySQL) with 10 queries
