#11 | |
Account Disabled
http://www.diyaudio.com/forums/showt...094#post627094 http://www.diyaudio.com/forums/showt...292#post627292 |
#12 |
Hello
Richie I`v heard about that book but it`s expensive and not on my mother language so it takes too much time to study it. I think that straight line current limitign is enough and i want to keep schematic simple as possible. Adrew I will use multiple transistors in parallel to reduce power of them. Yes power dissipation is still a problem but if voltage is +-50V and current is 8A power warms load and power dissipation of transistor is 25W (4 parallel). Worst case scenario of dissipation is a short circuit of outputs 8Ax60V=480W (voltagedrop of transformer not included) That means all 4 transistors have to dissipate 120W exremely much i think but i will never use supply with low voltages and high current i have no need for that. There will be over heating protection because of that. These transistors are bipolar Dhaen It is a bench supply for testing all kinds of stuff I can design power supplly with these properties but not with currentlimiting which will work allways no matter how load is connected. (For example +V to ground, -V ground, +V to -V.) Please correct if i`m wrong in some case |
#13 |
thanks for clarifying that you are building a bench supply. I was on the wrong track. All those nice transistors going to waste! You could intercept each winding and take off lower voltage taps. Then change the tapping as you change the output voltage. My bench supply has relays that do the switching automatically. As I ramp up the voltage with the control pot the relays come in & out selecting the appropriate voltages. This arrangement reduces the dissipated power considerably at lower output voltages and allows the use of a constant current control. The constant current control should be adjustable to protect a faulty circuit. |
#14 |
diyAudio Moderator Emeritus
K1jroth,
Current limiting is normaly done by including a small value resistor in the current path, either in the +, - or ground lines, then measuring the voltage across it. (The voltage regulation is not affected by the presence of the resistor if the error voltage signal is taken after the resistor). The voltage across this "current sense resistor" can be measured best by an opamp, but that requres external floating supplies. An simpler way is to use a small bipolar transistor which is biased by the voltage developed across the resitor. Here is an example Language: I believe that your grammar is rather different from European languages, so understand your reluctance to read Horowitz & Hill. However, if you can understand my muddled and sometimes confusing English, you will have no trouble to understand the clear and concise text of the book
| PCF80 -Designing a Pentode Constant Current Sink - help needed. | Shoog | Tubes / Valves | 18 | 31st July 2008 06:56 PM |
| Designing my first crossover, 2-way, advice on drivers needed... | nerd of nerds | Multi-Way | 10 | 10th November 2005 12:35 AM |
| needed: help designing push pull subwoofer | ramjet | Subwoofers | 3 | 18th April 2005 11:24 PM |
| help needed in designing gainclone | audioaction | Chip Amps | 14 | 31st August 2003 07:32 AM |
| Designing 6181/IGC integrated amp: help needed | Fred Dieckmann | Solid State | 14 | 31st May 2003 03:31 AM |
