#61 |
Electrons are yellow and more is better!
Can you elaborate your theories in practical terms? Have you actually designed a PS with 40 MHz bandwidth or more?
What do you mean "fast response time"? ns? I have never seen a 100 MHz PS from China or anywhere, have you?
/Per-Anders (my first name) or P-A as my friends call me |
#62 |
Hi guys
Have been modding a Marantz CD63KI for some time but get totally confused by all the conflicting advice on regulators. I have installed 4 simple LM317 based 5v regs using small tants for decoupling on small individual boards directly next to load around the DAC/Decoder section, which is after the caps etc on the PCB. I have seen banks of these regs built on a board at the edge of the CDP and fed by twisted wires to the load. I want to use better regs but my budget and skills are limited, so I think I need to build LM317/337 based regs with gyrators and use better decoupling/smoothing caps. Is it better to have the reg as close to the load as possible? Should I connect the reg through, say Blackgates to the load, and if so should the cap be nearest the reg or the load? Hope you can sort me out because I keep coming back to this and asking on other threads but no one seems to want to answer. Thanks in anticipation. Jim |
#63 | |
Caps: depends of the regulator. Look at the regulator datasheet for the type of caps to use. If you plan to reg digital, you can find many regulators better than the old LM317 (lower noise, faster transient). Good luke. |
#64 |
Thanks for that stef.
Any suggestions for replacements for the LM 317 for a 5v digital rail in a CD player? Regards Jim |
#65 | |
LT1086 (or LM1086) will be a good upgrade. Others exist but pinout will not be the same. I'm not sure that you will listen a difference specially on the 5v digital rail. . |
#66 |
OK thanks for the advice.
Jim |
#67 |
#68 |
| Lithos regulator - A new super regulator? | peranders | Parts | 7 | 8th May 2008 02:01 PM |
| Super Ultra Hi Power Amplifier | PicancoNet | Solid State | 28 | 31st January 2004 02:17 PM |
| Ultra low noise JFET voltage regulator | Kochkurov Maxim | Digital Source | 6 | 25th January 2004 11:33 AM |
| Page generated in 0.11871 seconds (72.76% PHP - 27.24% MySQL) with 11 queries |
