Need Help on Calculations for Negative TL431 with Pass Transistors!!
Old 27th April 2005, 10:58 PM   #11
hermanv is offline hermanv  United States
Default TL431 stability
I've had trouble with the stability of the TL431. The ON Semi data sheet warns about minimum current and pretty much assumes a large capacitor anode to cathode. I had some luck with a smaller capacitor cathode to feedback pin but be careful. There is a negative resistance state as the power is first applied, some circuits hang and won't pass this point without the large byass cap. It took a lot of work to find an unconditionally stable solution.
No it wasn't this amp it was in an isolated power supply feedback loop. So my difficulty or results may not apply.
Need Help on Calculations for Negative TL431 with Pass Transistors!!Hide this!Advertise here!
High/Low-Pass filter calculations Matttcattt Chip Amps 8 26th January 2005 06:38 PM
How to regulate a negative rail with TL431? JoeBob Solid State 13 4th September 2004 11:56 AM
Tl431 sparkle Digital Source 11 22nd February 2004 09:10 PM
Pass Labs A75 matched transistors for sale sivalleydiyer Swap Meet 3 5th May 2003 10:06 PM
Pass X2 and negative feedback BRunenr Pass Labs 10 20th May 2002 09:00 PM
