Too much voltage - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th April 2005, 11:31 AM   #11
K-amps is offline K-amps  United States
K-amps's Avatar
Originally posted by richie00boy
We know you get more power, but the issue is that there is a very real danger of encroaching on the output devices SOA. For any given load the danger becomes worse at higher operating voltages as you move up the SOA curve, even if you only let it play to the same power.
Yes father....
Old 7th April 2005, 11:42 AM   #12
Did it Himself
richie00boy's Avatar
Sorry if I came across the wrong way writing that. I knew you probably knew that, I was just saying it for the wider benefit
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 7th April 2005, 07:00 PM   #13
K-amps's Avatar
It's ok Richie... you caught me before my morning cup of Chai.
PS: The anticipation of a comment like yours was the reason I put in the disclaimer "assuming the amp survives"
Old 7th April 2005, 11:03 PM   #14
re circuit description in post 9; have you got CRC-CRC? i.e.30,800u- 1r0- 40,000u- 600u-1r0-1,000u. please clarify.
If I read correctly the final 1r0 before the small (2x500u) caps will cause significant signal induced ripple in the dc supply. Not good. Try moving the last 1r0 to between the rectifiers and first caps.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th April 2005, 01:09 AM   #15
I'll try that. Thank you!
Old 8th April 2005, 01:47 AM   #16
Mr Teal is offline Mr Teal  Canada
Remember, if you measured the 80V with no load, that will drop when loaded down. Depending on how quickly and how much it loads, you might be alright even at high power levels, since by the time you're drawing current and heating the device, the PS voltage might be back below 75V.
Old 29th June 2005, 03:29 PM   #17
Could you send me the values of the p101 project?
Thakns anyway.
Guettomusick@gmail.com
845 Low voltage SE AMP =maximum= Tubes / Valves 16 20th January 2013 02:31 AM
Should I use high voltage value zeners or multiple lower voltage zeners in series? jarthel Parts 7 30th May 2006 04:56 PM
Rail Voltage to Capacitor Voltage Mermprin Parts 6 20th September 2004 03:56 PM
secondary voltage vs. primary voltage Stocker Parts 5 11th March 2004 07:41 PM
Rail voltage compared to transformer voltage SteveG Solid State 4 22nd July 2002 11:50 PM
Copyright 1999-2017 diyAudio
