Unknown Toroid Transformer VA - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 11th April 2005, 07:31 AM   #21
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by mrlots2do
How will wiring primary coils in series effect va output?
Will va go up or down with primary in series?
What would fuse sizes be this way?
VA will go down, but not halved, because secondary wires are overdimensioned.
Moamps could tell you what you can expect, he used transformers with primary's in series a number of times and measured max output.
For big transformers he named 70 to 80% of nominal VA.
You can measure the diameter and resistance of the secondaries, and look in a wire chart how much current is acceptable
If you need even lower voltage after putting the orimaries in series you can unwind the secondaries without hurting the VA number.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 11th April 2005, 01:30 PM   #22
mrlots2do's Avatar
I weighed the two toroid transformers this morning, both weighed 5.5 lbs (2.5 Kg).
Originally posted by jacco vermeulen
You can measure the diameter and resistance of the secondaries, and look in a wire chart how much current is acceptable.
Would the lead wire gauge be the same size as the secondary wire gauge or will surgury be required to determine that?
Can you give me a link to a wire chart?
Old 11th April 2005, 03:11 PM   #23
Type: AWG wire table in google, lots of 'm there.
Secondaries are the thicker ones, as more current is supposed to go through.
Old 27th April 2005, 04:37 PM   #24
mrlots2do's Avatar
I found this on Plitron's website. The information appears to be very useful to all trying to determine VA rating of toroid.
Temperature Rise
Figure 11 illustrates the rise in temperature of a Standard Power toroidal transformer in relation to output loading. PLITRON’s Standard Power Transformer Line is designed to 40 deg. C temperature rise above ambient. Temperature rise drops drastically with load: at 50% load, temperature rise will be about 25% of the rise at full load.
So....
50% transformer va will have a temperature rises of 10 degrees above ambient temperature. Sounds easy to check, anyone try this with know VA values.
New subject, fuse sizes, haven't found calculation for that yet.
120v primary of 240VA transformer, would I install 2 amp primary fuse.
24v secondary of 240VA transformer, would I install 10 amp secondary fuse.
Old 28th April 2005, 06:51 PM   #25
I doubt the transformer will start with a 1A fuse so just try it with a 2A.
Until you know more about you transformer I would rather you fitted lower rated secondary fuse, try 3A or 5A.
Another thing to do to protect yourself and the transformer is fit an inline light bulb in the primary circuit. Only heard about this recently on DIYaudio and it's so simple and foolproof that I went & built one.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th April 2005, 07:13 PM   #26
mrlots2do's Avatar
Good suggestion
What did you use as light bulb?
Unknown Transformer 6f6 Tubes / Valves 4 5th April 2007 06:14 PM
How to characterise unknown transformer pixpop Parts 1 31st January 2005 08:40 AM
Unknown transformer rating?? bigparsnip Parts 4 4th June 2003 09:26 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Copyright ©1999-2017 diyAudio
