EI transformer orientation
Old 28th March 2005, 04:00 AM   #1
ultrachrome is offline ultrachrome  United States
Default EI transformer orientation
I have an EI transformer that I am using in a solid-state preamp. I'm about to mount it in the chassis and I'm wondering which way I should orient it. In other words wich side should face the pre-amp circuit?
It will be about 4-5" away and I must cut a hole for the bottom of the transformer to pass through, so I need to get it right the first time.
Thanks.
Old 28th March 2005, 07:01 AM   #2
sivan_and is offline sivan_and  India
sivan_and's Avatar
Send a message via Yahoo to sivan_and
Best orientation is that gives minimum HUMMMMmmmmmmm.
Make suitable mouting holes,in a way that it can be rotated 90degrees..
SivanandBalan
Old 28th March 2005, 01:11 PM   #3
R.I.P.
Is it possible to loose mount it before cutting any hole?
Try rotating it to several orientations to find the quietest.
regards Andrew T.
Old 28th March 2005, 04:11 PM   #4
I had it all on a piece of plywood when I was testing it and had no hum. I then took it appart to build the enclosure.
I just read that most of the magnetic field is projected out the exposed sides, where the end caps usually go. In this case that is the top and bottom. It seems that it doesn't matter which way it's rotated as long as the laminations are pointed at the circuit.
EI transformer orientationHide this!Advertise here!
orientation of bypass cap user_manutd Digital Source 3 30th March 2009 04:23 PM
op/amp orientation question rtate Digital Line Level 1 2nd January 2009 08:57 PM
Transformer orientation Skorpio Pass Labs 5 12th May 2006 01:25 AM
Mains transformer orientation Rocky Tubes / Valves 20 23rd November 2005 10:52 AM
Toroidal transformer mounting & orientation nic.hanno Parts 0 9th April 2004 11:32 AM
