PFC Switched-Mode Power Supply - Page 6 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th May 2005, 09:59 AM   #51
Alme
thanks
you know, with L4981A,the boost circuit output is always 400VDC, but if i want to get some useful voltage, just like 24vsc,36vdc,or 48vdc, what should i do from the circuit?
thanks.
Old 20th May 2005, 11:44 AM   #52
Ouroboros's Avatar
Do you really need power-factor correction for your charger?
If not, then for your 180W supply I suggest you have a look at the two-transistor forward converter design help at the following site.
http://schmidt-walter.fbe.fh-darmsta..._e/smps_e.html
This will help you design the transformer and the output inductor.
If you really do want PFC, then you can use the L4981 to give you a 400V dc supply, and then use this +400V to feed the two-transistor forward converter. The isolation is done in the forward converter transformer. You can use a control chip such as the UCC3801 for the forward converter, and something like a IRF2110 (or a suitable transformer) to drive the gates of the power FETs. You will also need to learn about using a TL431 and an opto-coupler for the output-sensing feedback, as this has to cross the isolation barrier.
If you want to charge lead-acid batteries you may need to add temperature-compensation to the float chage voltage, to ensure long battery life.
Old 21st May 2005, 02:59 PM   #53
well ,Ouroboros,
thanks for your explanation. it's very useful for me.
our tutor want to design a robust, and he ask me to design a battery charger for the robust.
what i want to design is a half bridge circuit, with 220vac 50hz input, and 36vdc 5A output for battery storage charger,
and i want to use a IC (such as L4981) to drive the two MOSFETs, i just post the circuit in a word document, 220vac---transformer---half bridge---battery storage , could it be done?
may be SG3525 IS suitable cause it has two output pins, but I havn't made itvery clear.
i want to pose the circuit here , but it's too big.
Old 21st May 2005, 03:02 PM   #54
sorry i made a mistake,
not"robust",it's "robot" automatic machine
Old 27th May 2005, 12:21 AM   #55
DavidF is offline DavidF  United States
Default ML4826
I'm jumping in to mention that the ML4826 is available from Fairchild www.fairchildsemi.com N-Channel had been looking for it early in this thread.
Has anyone used this chip? I'd be interested in any comments on it.
David
Old 27th May 2005, 01:16 AM   #56
Kenshin is offline Kenshin  China
Kenshin's Avatar
Buy a electric bicycle charger for 36V lead-acid battery.
Originally posted by davy_shi
well ,Ouroboros,
Old 7th June 2005, 02:31 AM   #57
N-Channel's Avatar
Send a message via AIM to N-Channel
Default ML4826 PWM-PFC Combo chip
DavidF-
I am so braindead! I just found the datasheet for the Fairchild Semi ML4826 in my stack o' stuff last week. I forgot I had downloaded it a few months back. I am planning on getting a few samples from Fairchild and giving them a test, but with new child and family, it will be a challenge on getting some time to do this.
Steve
Old 13th June 2005, 07:56 PM   #58
Default Anode/Cathode on an IXYS diode?
Im sorry, but I can not find this info anywhere;
On an IXYS 12A 1000V Ultrafast, Soft Recovery (FRED)
Epitaxial Diode (trr = 50 ns; TO-220AC package)...
... I cant seem to find out wich is the "anod" and wich is the "cathod"?
Please advise.
Mike
switched-mode power suppies Dimitar13 Everything Else 0 19th February 2008 12:50 AM
Switched mode power supply MMicke Car Audio 3 19th February 2005 10:42 AM
filtering switched mode PSU for SI 5066 amp supply jives11 Parts 0 24th January 2005 09:19 PM
Switched mode power supplies Magura Parts 13 3rd January 2004 05:44 PM
Switched Mode vs Linear Power Supply royalmp2001 Solid State 4 12th July 2002 08:04 PM
Copyright 1999-2017 diyAudio
