PFC Switched-Mode Power Supply
Old 1st March 2005, 01:17 AM   #11
MARAVILLASAUDIO is offline MARAVILLASAUDIO  Spain
Send a message via AIM to MARAVILLASAUDIO Send a message via MSN to MARAVILLASAUDIO Send a message via Yahoo to MARAVILLASAUDIO
Default MAS
MAS
Old 16th March 2005, 03:26 AM   #12
Alme is offline Alme  Ukraine
Default I have just received a new PFC solution from IR news
http://www.irf.com/whats-new/nr050307.html
Looks attractive.
'One cycle control' is something new to learn.
Old 16th March 2005, 03:49 PM   #13
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Default New PFC Chip
Alme-
I agree. It looks promising, and could really simplify the design of the PFC Pre-converter stage.
Old 18th March 2005, 04:26 PM   #14
N-Channel's Avatar
Default My PFC Front End
I have noww figured out (with a little help from folks here) how to shrink the size of pic files to get under the 102kB size limit. Later today I will post pic(s) of my MC33262-based 180W PFC Front end. Note the series-connected output caps, as this provides a convenient midpoint for a half-bridge DC-DC converter to be connected to.
Steve
Old 19th March 2005, 11:29 AM   #15
Steve, I think the best way to have small size schematic pictures is to save them as GIFs (compresses very effectively if image has only a few colors). now , I'm waiting for your PFC ideas
Old 19th March 2005, 07:55 PM   #16
N-Channel's Avatar
Default Picture (at last!) or PAL
Here it is. Resized to 94kB..............
Old 19th March 2005, 07:58 PM   #17
N-Channel's Avatar
Default PFC Components
The rectifying diodes are MUR8100's, and the MOSFET is an MTW20N50E, 500V- 20A N-Channel. The control IC is a Motorola MC33262. The output caps are Panasomic 390uf 250V each.
Old 24th March 2005, 12:47 PM   #18
Steve, sorry for not answering till now, I've been busy with work.
So assuming that you use such high-voltage components, your PFC output voltage is about 400V, am I right? (390uF caps in series? )
can you post its schematic please?
By the way I begin to think that PFC issue is too far from audio guys focus since there's no others' contributions to the topic That's maybe true; I have interest in it because I've been both audio and power electronics engineer in my practice.
Old 28th March 2005, 01:42 AM   #19
N-Channel's Avatar
Default PFC Output
Alme,
I set the output voltage for about +390V, and the two 390uF caps are each 250WVDC, and, yes, they are in series. The schematic I used was from the old Motorola data book for their discrete semiconductors. This was a 180W universal input PFC for the MC33262. Basically, this is the extended temperature range version of the MC34262. Here is the link:
http://www.onsemi.com/pub/Collateral/MC34262-D.PDF
Instead of the one 220uf Output cap, I substituted 2-390uF Caps for the half-bridge centertap, and their almost double value over the original 220uF is because since they are in series, their effective value is halved. And for the MTP8N50E. I substituted the now-discontinued MTW20N50E N-Channel MOSFET. The input rectifiers are MUR 8100's. The input rectifiers need to be ultra-fast types because now, high-frequency pulses are being drawn off the AC line.
Steve
Old 28th March 2005, 01:41 PM   #20
Steve, in your pointed pdf they say that it's one of advantages of critical-conduction mode - flyback diode actually shouldn't be ultrafast type there (rather cheap 250ns standard recovery type will fit). On the contrary, fixed-frequency PFC needs diode as fast as possible (25-35-50ns type) because it switches full current at the moment of going into reverse bias.
So what is the intention of your PFC? What you supply thru it?
PFC Switched-Mode Power SupplyHide this!Advertise here!
switched-mode power suppies Dimitar13 Everything Else 0 19th February 2008 12:50 AM
Switched mode power supply MMicke Car Audio 3 19th February 2005 10:42 AM
filtering switched mode PSU for SI 5066 amp supply jives11 Parts 0 24th January 2005 09:19 PM
Switched mode power supplies Magura Parts 13 3rd January 2004 05:44 PM
Switched Mode vs Linear Power Supply royalmp2001 Solid State 4 12th July 2002 08:04 PM
