Differece between Avel and Plitron?
Old 24th February 2005, 04:05 PM   #1
G4ME is offline G4ME  United States
Send a message via AIM to G4ME
Default Differece between Avel and Plitron?
This spring, I am looking to construct a chip amp, implementing some national chips, I am still in the research phase. Right now I am looking at the power supply section and looking at different toroids. I have come across Avel and Plitron toriods, but the price difference is rather different, around 30 bucks more for the Plitron. I was just curious what this 30 bucks more is getting me, better tolerances? better efficiency? there seems to be little different in shielding.
I am looking at a 625VA with dual 25v secondaries.
My instincts say go with the cheaper on as its just a transformer, but I am just looking for different opinions on this, thanks.
Two little mice fell in a bucket of cream. The first mouse quickly gave up and drowned. The second mouse, wouldn't quit. He struggled so hard that eventually he churned that cream into butter and crawled out.
Old 1st March 2005, 11:47 AM   #2
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Anyone have some info on old Plitron code numbers ?
Or, tell me what this Plitron code means:
1151756-05-1722
Up till the first 4 digits it matches new Plitron numbers:
11 = 1000va
5 = 100/120/220/240 Volts 50/60 Hz
1 = electrostatic screen
Starting from the 7 i am lost.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 1st March 2005, 12:31 PM   #3
BobEllis is offline BobEllis  United States
BobEllis's Avatar
I use an 860 VA Avel transformer in my 4 channel Leach amp. Regulation seems good, and there is no mechanical noise. I've also had good results with the Toroid of MD units in my A75s.
I haven't used Plitron, but I have heard that Pass does.
IMHO, in a class AB amp as long as it is reasonably sized (VA at least 2x output), transformer quality differences will not really be noticeable. Remember that in reality you will be using a very small part of the transformer's capability most of the time.
In a Class A amp, where you are drawing heavy current all of the time then build quality becomes more of an issue. I get a little mechanical hum in my A75s during the inrush surge, then they are silent.
Old 1st March 2005, 12:42 PM   #4
I have used quite a number of toroid brands in the past, usually because they came free or cheap.
Anything from Plitron, till stuff from Spain.
None of them were really bad ones.
Sort of like driving a dodge or a caddy, if they are in good condition both will get you there.
There is a difference in build quality between different brand toroids.
I have a lot of experience with ILP, Amplimo nowadays, because that is the standard toroidal transformer overhere for 25 years.
Plitron and Amplimo are equal quality transformers.
There are manufacturers in Great Britain that make above average quality transformers.
Holden& Fisher used to be the favorite untill they went bust, like Partridge was with Tube output transformers.
H&F was the most common used transformer in US amplifiers.
Now it seems to be Plitron that is no1.
If you do not desire the best, go for economy, is my advice.
Old 1st March 2005, 02:38 PM   #5
K-amps is offline K-amps  United States
K-amps's Avatar
Nelson has used the Avel's in the past.
Avels (Y23) series are now made in China, thus they can be had for a steal. For non-critical and non-aesthetic applications, AVEL's are fine. They have great after sales service and tech support.
However I do need to report, I once bought a 1kVA directly from Avel which upon installation heated up abnormally (in a class-AB Adcom 545ii) it got to 50c on idle... (the 545ii did not draw more than 20 watts at idle) while the rails were steady, this is did not jive well with me. A call to Avel got me shipped areplacement at NC to me. The replacement worked fine.
In the past year I have used / installed 16-20 800va to 1kVA Avel Y23 series with only one heating up.
The Avels do not look very professional, the windings crossover each other at places and does not sit too well.
For Class-AB amps, I have used them with little or no issues, however for a class-A amp, I'd go victoria magnetics or Plitron.
I hope this assessment was fair and balanced (FOX? ) and helps you in your thought processes.
One more thing despite the shabby build of the Avel Y23 series, they are DEAD quiet with little or no stray emissions. I put two 800va toroids on top of each other and 2 inces from the amp's input diff stages... NO hum whatsoever.
K-amps.
Old 1st March 2005, 02:51 PM   #6
K-man,
does Victoria equal Plitron in quality ; winding and taping ?
Difference in cost between the two ?
J.
Old 1st March 2005, 02:59 PM   #7
K-amps's Avatar
Jacco,
Both are very good. I prefer Victoria because a 1kvA custom victoria costs $95 here in the US, Plitron standard (no custom) 1kva costs $113 plus shipping to US so about $140. Not big difference but the fact that I can get custom primaries for no extra charge etc makes me go to Victoria.
However Victoria is a small shop, they sometimes dont have the cores and they may not be able to fulfill the order for 3-4 weeks depending on the load. Plitron can send you as many as you want. So manufacturers tend to go Plitron. It is less expensive than Hammond and some other makers and very good quality. My krell has a Plitron. Nelson (and the Canadian dudes) also use Plitron.
K-man.
Old 1st March 2005, 03:15 PM   #8
Canadians build amplifiers ? No kidding !
I read your words as that Victoria is very attractive for custom made toroids.
Next time i need a custom job i'll send an email down south.
Thanks, K-ampy
J.
Old 7th March 2005, 11:37 PM   #9
KBK is offline KBK  Canada
Plitron and Hammond are practically a stone's throw from each other. Both in the Toronto Ontario area, If I recall correctly. Hammond now makes Toroids up to 1500VA.
Canadian amplifier companies:
Classe
Bryston
SimAudio
Blue Circle
etc
etc...
"Extraordinary claims require extraordinary evidence." - Carl Sagan. Sometimes the claims aren't extraordinary. Sometimes the weakness of men's minds are the culprit. Mass mentality has nothing to do with obviousness or truths.
Old 8th March 2005, 12:22 AM   #10
K-amps's Avatar
You mean a Toroid's throw away
by the way, Hammond are kinda pricey, Plitrons are very good for the price.
Differece between Avel and Plitron?Hide this!Advertise here!
Any diff if in F3: Plitron vs. Avel Lindberg? riotubes Pass Labs 21 8th December 2008 01:50 AM
Improve Avel toroid in OTL amp ad010685 Tubes / Valves 0 15th September 2007 01:13 PM
FS: Avel 625VA 30V+30V Transformer mfb Swap Meet 1 12th July 2007 06:59 PM
New Avel Transformers Available BobK Chip Amps 0 3rd December 2004 06:30 PM
FS: Avel Y23 25-0-25 120VA transformers mhb Swap Meet 0 25th February 2004 08:07 PM
Copyright ©1999-2017 diyAudio
