i need a schematic for a variable power suply , ajustable between 12-50V and between 0.5-5(6)A....and i need bothe pozitive and negative regulators, becaude i need +,gnd,- .....
i found something, but not more then 30V....something like lm317,(i think) + one or 2 power transistor....problem is that i need to be up tu 50V...and i need also to be able to control what the curent is going trough.... i don't need a small riple, about 50,or even 80-90-100 mV will do fine... can someone help me...???? |
#2 |
you can use the LM317HV (high voltage version of the LM317) with a pass transistor -- but for +/0/- you will need a transformer with two independent secondary windings -- the negative supply is regulated in its ground return (which is, after all, positive) .
#3 |
yes,jackinnj i did not know about the LM317HV ,only about the LM317....
i found this schematic in the datasheet, what do i need to change for this to work with hier suply voltage...let's say a 50-55V input and stil deliver a 5 A at the output,or even better a 6 A....or it will work as it is at this voltage...???(also i will double the output tranzistor, 2 are better then one, and at 50V and 5 or 6 A one will be not enaugh...) |
#4 |
try lm350 , its an old but good regulator and i can get 'em with no problems, the max voltage is 33V i think but it can be floating - the max voltage is the input to output voltage on the regulator , so u can use 50V supply but u can go down to 50-33= 17V
there is schematic in the datasheet how to parralel em'
if you are not living on the edge you are taking too much space
#5 |
You better have a lot of heat sinks and fans. If you really want 5-6 amps over that voltage range you're going to have a lot of heat to dissipate. This application begs for a switching supply, not a linear.
One possible solution would be to use a transformer with dual primaries and have a high/low range. Use the primaries in parallel for the high range, and in series for the low range. Note that you'd have to derate the available current from the transformer at least 50% on the low range to avoid burning up the primaries. Make sure that the power supply is stable over a wide input voltage range. 108-132 VAC is standard. |
#6 |
Take a look at:
http://www.a-and-t-labs.com/K2_Lab_P...pply/index.htm If you need that output current when using low voltages you will, as mentioned, need serious heatsinking. Try and use pre-regulation by either switching the charging of the reservoir caps or by switching different transfomer windings depending on voltage needed. Janneman presented a circuit for this while back.
UrSv Those who say it can't be done should not stop those who are doing it. |
#7 | |
Note the fan and "wind tunnel" heat sink. ![]() and ![]() Today's bjt transistors can take a lot more punishment, the error amplifiers are better and we seem to know a bit more on how they should be compensated. You will be pretty surprised at how well an LM317HV works with a couple external pass transistors. (unfortunately, there isn't an LM337HV -- that's why you need a trannie with two independent windings -- not too difficult to find, however.) |
#8 | |
thanks a lot!!! |
| fixed tovariable power suply | salil_kamat2 | Power Supplies | 3 | 8th December 2006 01:41 PM |
| Power suply reduction | leander | Solid State | 2 | 9th September 2005 07:54 AM |
| power suply help needed !!!!!!! | mircea | Chip Amps | 0 | 28th June 2004 03:33 PM |
| Aleph5 caps for power suply | cducati | Pass Labs | 2 | 20th February 2003 09:16 PM |
| LM3886 power suply... | JoeBob | Solid State | 31 | 7th January 2002 01:36 AM |
