Reference zener in Series regulator
Old 4th February 2005, 02:31 PM   #11
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Maybe you should try a Jung Super Regulator with a LM329 as voltage reference?
Just wondering, how low noise do you need?
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 27 pcb's in interest.
Old 4th February 2005, 03:26 PM   #12
claudio is offline claudio  Italy
claudio's Avatar
Hi Peranders,
the pre is a single stage cascode, so the lower the noise the better. The schematic is here: cascode thread
I have to choose between the Jung SR II (the one presented in 2000) that uses the LM329 as you said, or a classic series regulator. I don't need a negative voltage, but 33-36 Vout is needed.
Is the Jung SR II limited to 30 Vout, as your version of it (JSR 01) ?
Claudio
Old 4th February 2005, 03:31 PM   #13
peranders's Avatar
The Jung Regulator itself is limited by max voltage for the used opamp, 36 volt normallly.
Old 5th February 2005, 04:13 PM   #14
jackinnj is offline jackinnj  United States
jackinnj's Avatar
if you need really, really low noise you can put 4 references in parallel --there was an application of this in Sep/Oct 2001 QEX in which 3 Thaler VRE305A references and chopper amplifiers were used to create an ultra low noise ref for a DVM --
Maxim has an application note where they use 4 voltage references in series, sum the outputs and divide.
Reference zener in Series regulatorHide this!Advertise here!
Zener + Emitter Follower voltage regulator Alcaid Solid State 90 2nd June 2010 12:12 AM
zener regulator till Solid State 29 26th March 2008 10:39 PM
Suggestions for a high-power low noise Zener regulator ? youyoung21147 Power Supplies 0 29th November 2005 12:48 PM
Sound of dud zener or 7824 regulator george a Solid State 4 21st February 2005 01:15 PM
