Regulator choices...
Old 16th January 2005, 07:37 AM   #11
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
However, this doesn't answer the question, "why would somebody buy a complimentary pair of regualators?"
But it does. In many situations you have to use a centre-tapped transformer. And you save a bridge rectifier.
It seems though that in practice the complementary regulators are not quite identical - the positive often perform better than the negative. In such situations using a positive regulator for both rails is better.
Old 28th January 2005, 07:47 AM   #12
kkchunghk is offline kkchunghk  Hong Kong
Wink using positive reg. for negative supply
Hi fellas,
I bought a pair of LT1086 positive adjustable regs. on the advice of some net page claiming it wraps rings around the old 317. The data sheet from LT actually shows how a full range supply can be built by using just positive regs. Here is one design which I adapted from the data sheet. I plan to use it for chip pre amp and head phone amp, and a spare for tone control (shock horror!), hence three outputs. The rails are +/- 18v from a 2x18v transformer. The only thing I might add is AC filter before the bridge.
Hope this helps.
KK
Old 28th January 2005, 10:13 AM   #13
moamps is offline moamps  Croatia
Default Re: using positive reg. for negative supply
Originally posted by kkchunghk
.... Here is one design which I adapted from the data sheet.....
your design has serious error.
Milan
Old 28th January 2005, 10:27 AM   #14
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Question Re: Re: using positive reg. for negative supply
Milan
Such as?
Old 28th January 2005, 10:33 AM   #15
UrSv is offline UrSv  Sweden
UrSv's Avatar
Shorting the lower regulator which is connected in a way that would not work?
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 28th January 2005, 10:44 AM   #16
Yes.
Old 28th January 2005, 12:58 PM   #17
AndrewT is online now AndrewT  Scotland
you need separate secondary windings, rectifiers and capacitors.
Keep both the + & - regulation completely separate and only after the regs connect the positive of reg1 to the negative of reg2 and call this connection common.
regards Andrew T.
Old 28th January 2005, 01:46 PM   #18
Unhappy psu
Hi Milan,
Thank you. I spotted the mistake after I post the schem. It should look like this. It shows that you have to be lightning quick in this forum.
KK
Old 28th January 2005, 02:28 PM   #19
sorry, but this design doesn't work too.
Read Andrew's post, please.
Milan
Old 28th January 2005, 06:08 PM   #20
Question another go
Hi Andrew T and Milan,
Thank you for pointing the right direction. I think you two gentlemen are refering something like this. The preoccupation of skimping a rectifier, and saving PCB space led me the wrong way.
Any comments on this one?
kk
Regulator choices...Hide this!Advertise here!
various t-amp ps choices svgsnd Class D 2 28th February 2006 03:14 AM
tell me the best of three bad choices... chipco3434 Digital Source 10 23rd April 2004 10:09 AM
Home Theater Combo - choices choices smithsonga Multi-Way 1 2nd April 2003 06:11 AM
