#11 | |||
Thanks for the replies
Both the grounds will be connected at a single point after all.Quote:
SG3525 featuring soft-start .. Yup, I think I need a high side driver Quote:
#12 |
might want to look at this thread
http://www.diyaudio.com/forums/showt...888#post240888
intentionally blank |
#13 |
A rough schematic...Exact working values will be posted as soon as i get to my home....
SivanandBalan |
#14 |
@davesaudio
Kind of different but it helps @sivan_and SG3524 huh .. umm .. I see the difference .. Will think about it, and thanks
#15 |
I would appreciate the particular application needs.
Minimum and Max i/p voltage. Load Current and output voltage. Type of load..etc
SivanandBalan |
#16 |
Still not figure out the application for it yet, +/- 12V should be useful. Just try to build some converter myself.
Input voltage is +25V .. might need zener diode or diode here. Output voltage is -12V (require soft start ?). +12V is ok too. Resistive load 15ohm. So, load current = 0.8A. Mosfet p-channel IRF9540 ? The values above are not fixed. Vi = 12V Vo = 5V R = 10 ohm or 15 ohm are fine too. And, thanks for your responces
| Orion MBR70 battery isolator | oPossum | Car Audio | 1 | 21st June 2009 11:22 AM |
| Velcro as Vibration Isolator | Buckapound | Parts | 5 | 9th May 2009 07:58 PM |
| question about isolator behind transistors | Ground Zero | Parts | 3 | 28th January 2009 09:56 AM |
| DIY cable tv ground loop isolator. please help | imperfectcircle | Parts | 0 | 31st January 2007 10:13 PM |
| Looking for optical isolator for audio | FastEddy | Solid State | 0 | 27th September 2006 06:40 PM |
| Page generated in 0.10931 seconds (67.05% PHP - 32.95% MySQL) with 11 queries |
