Borbely PS has 5 uV noise and ripple - little or much?
Old 24th December 2004, 06:58 PM   #11
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Default Re: Re: Borbely PS has 5 uV noise and ripple - little or much?
Originally posted by Elso Kwak
Hi Sigurd,
But how does it sound?
Or do you believe low noise automatically implies good sound?
LMAO... it obviously doesn't, example the continued, and even hi-fi existence of phonograph recordings.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 24th December 2004, 07:37 PM   #12
Kevinbd is offline Kevinbd  United Kingdom
Originally posted by AndrewT
noise and ripple is approaching -130db.
That is good, maybe very good, some might even say excellent.
An alternative would be Jung. There is a thread here with all the construction details and it has similar performance. I would guess both have quite fast response.
regards Andrew T.
I seriously doubt it has 130db of PSRR. It doesn't have a current mirror and current source for the differential for starters. The RC filter after the voltage source feeding the jfet diff is a nice touch though.
I think it is extremely difficult to get 100db + PSRR in a discrete design and get low output impedance. Then HF performance is likely to be alot worse.
Not commenting on it's sound though.
Old 27th December 2004, 02:24 PM   #13
R.I.P.
I have only converted the noise voltage of the PSU into decibels to give a reference.
This is not the PSRR of the opamp that might use the PSU.
regards Andrew T.
Old 27th December 2004, 02:38 PM   #14
uli is offline uli  Austria
*ROFLMAO*
I seriously doubt that you have read the thread properly!
We are talking PSU
Where do you find PowerSupplyRejectionRatio in a PSU???
There are current sources in the legs of the diff amp.
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 27th December 2004, 07:50 PM   #15
Sigurd Ruschkow is offline Sigurd Ruschkow  Sweden
I bought the power supply kit, and have now assembled it.
Assembly was a piece of cake. All the small bags with components really made it foolproof to mount all the components.
Setting it to the desired voltage was simple, and the voltage is very stable.
Components are of very high standard!
I was positively surprised
Dale resistors,
cermet potentiometers,
Cerafine Fine Gold electrolytics,
Mundorf film caps,
Wima polyprop caps,
JFETs and MOSFETs.
If you are looking for a good regulated PS with good components, I recommend you to check it out.
Sigurd
Old 22nd January 2005, 10:06 AM   #16
Default Re: Borbely PS has 5 uV noise and ripple - little or much?
Here are some photos I shot of the regulated power supply and the recifying supply kits.
Sigge
Originally posted by Sigurd Ruschkow
Hi all,
I am looking for a good regulated power supply (+-24 V) for a buffer. Borbely's designs seems to have a good reputation. One of his power supplies is shown below.
Is can support 200 mA so it is a bit oversized but that is to my liking :-)
The spec says it has 5 uV ripple and noise over the audio bandwidth.
Is that much or little for a regulated PS?
How does one measure such low voltages?
Sigurd
Old 2nd April 2005, 11:38 AM   #17
Elso -
at last, I now have the 254 together with a Borblly Superbuffer1 and an unregulted PS 309 also from Borbely.
Here are some sonical impressions I have. I compared the Superbuffer1/254/309 with a TX102 transformer volume attenuator.
I use the Superbuffer1 with Teflon PCB and Caddock high resolution MK132 resistors for the input, output, and feedback resistors. I also opted for the high output current option that is supposed to give better bass (and the SB1 can now also drive 600 Ohms, which I do not need). Instead of the voltage references, I have installed blue LEDs.
Transformers are 225 VA toroids from Amplimo that are potted, and shielded against both magnetic and electric fields.
The Borbely preamp is built up like dual mono from the AC outlet and onwards.
A mains net filter from Schaffner is also used for each channel.
For the stepped attenuator I use DALE's CMF55 non metallic resistors.
Silver wire is used for signal wires.
Standard gold plated chassie RCA connectors.
To summarize
Both me and my wife find that Borbely's Superbuffer1 sounds better than the S&B TX102 transformers. More detail, more slam, another octave of deep firm bass, and better focus and clarity on voices.
Sound comparisons
Both these preamps are of very high quality both regarding component choice, mechanical properties, and sonically. No doubt about that! Still, it was not that hard to hear that they did not sound the alike.
I built the TX102 preamp some months ago. The sonic character I hear is a smooth, bass-rich sound with great sound stage, a polished treble that is never hard or cold, and a body for each individual instrument (on good recordings) that can be very appealing. Details are OK. Transients could be better.
The preamp made up out of Borbelyäs designs has been online since a month and the SB1 is now fully burned-in. It sonic character is one full of details, resolution is higher than I ever had heard before, each instrument is clearly heard through a mass of instruments with a very good focus and body. The body I heard on the TX102 preamp is more muddy in comparison. Voices are better as they are easier to hear, more realesed, with better clarity. Soundstage is great with wonderful depth. Transients scaringly fast. Slam is fantastic. Bass is firm, powerful and deep. I did not know that my speaker could deiiver such a deep bass.
Sigurd
Hi Sigurd,
Borbely PS has 5 uV noise and ripple - little or much?Hide this!Advertise here!
Borbely DAC board Prune Digital Source 22 17th September 2011 08:51 AM
FS Borbely Headphone Amp flocchini Swap Meet 0 19th September 2008 07:15 PM
Has anyone used Erno Borbely EB-201/168 ANALOG GUY Solid State 14 8th February 2006 10:26 AM
Help me regarding very low Supply Ripple output noise DC volume control unit electronist Parts 0 31st December 2003 09:29 AM
