diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   Car Amp Power Supply (http://www.diyaudio.com/forums/power-supplies/46919-car-amp-power-supply.html)
DSchmidt 1st December 2004 10:02 PM
I've got a basic question about building a power supply for a car amp. Generally, do you go to 110V AC and then use a standard transformer or are there step-up transformers that are used to get up to about 35V dc?
tsmith1315 1st December 2004 11:11 PM
Typically car amps use switching power supplies. DC from the battery is chopped into quasi-square waves by switching transistors. This AC can be stepped up and filtered for whatever voltage your amp needs.
It's definitely more complicated than a typical 110V to DC supply.
Do a search in the Car Audio forum for SMPS or Switch Mode Power Supply, and you should find plenty of discussion and links.
Tim
harp mg 31st March 2011 04:27 PM
build this one . it works!
Switchmode Power Supply For Car Audio
Resources saved on this page: MySQL 18.75%
