#51 | |
#52 |
Yes, a positive feedback is usually added into comparator circuit to help improve response time or make latching effect.
Looks like it is basically possible to add hysteresis into transistor sensor as well; I didn't try it though because used such sensor for current limiting type OCP, not latching shutdown. I think series diode plus resistor connected from Q3 collector to Q1/Q2 base can do such job. When thresholding, feedback resistor would be connected in parallel to R2, thus decreasing R2/R1 ratio. Certainly there also must be Q3 pull-up to allow this, actually pull-up will take part in R2 paralleling action, but feedback resistor is going to be of much higher value than pull-up (say, 470k vs. 10k). |
#53 | |
Hi there ....that is why in SMPS designs I always use a driver ic rather than directly connecting the power mos/igbt to the control chip. YAnd you get far more stable operation. richj |
| Split Voltage Switching Power Supply for Power Amp | vectorplane | Swap Meet | 2 | 23rd April 2011 11:48 PM |
| Switching Power supply | allanon77 | Solid State | 31 | 25th June 2010 06:41 AM |
| Switching 12V power supply PCB | soundNERD | Power Supplies | 35 | 27th April 2005 01:35 AM |
| Switching power supply | Thomas B | Pass Labs | 15 | 9th December 2002 10:28 PM |
