Improving on LCaudio LowNoise regulator
Old 29th November 2004, 11:11 AM   #11
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
You are absolutely right. I missed that Gilmore's example to the reference voltage from the regulated output.
Anyway, I can't see the real benefit of a tracking supply in an audio application.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 52 pcb's in order. 31 paid.
Old 29th November 2004, 11:31 AM   #12
Bricolo is offline Bricolo  France
Bricolo's Avatar
always symmetrical rails, independently of the variations?
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 29th November 2004, 11:40 AM   #13
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb Dual Tracking Regulator
Per-Anders, I knew Quirck was right....
You really should consult Horowitz to see any advantage......
Here is an example more to your taste (more parts, complicated design, not SMD though):
It is for the Mark Levinson ML-7 preamplifier.
Old 29th November 2004, 11:42 AM   #14
Banned
Default second part
nt
Old 29th November 2004, 12:01 PM   #15
peranders's Avatar
.. but why has it to by symmetrical in the first place!
Old 29th November 2004, 12:15 PM   #16
Bricolo's Avatar
maybe the variations on the ps rail aren't transmitted to the output in a symmetrical tracking ps
imagine an opamp, AC coupled signal going into it.
If the ps rail are -12 0 +12, 0V DC at the output
if there's a variation on the ps rail, but the ps is a tracking one, the rails become -10 0 +10, still 0V DC output
but if the ps isn't tracking, the rails can become -8 0 +12, and here you'll have DC
Old 29th November 2004, 12:46 PM   #17
Lars Clausen is offline Lars Clausen  Denmark
Well in case of extra load on either the positive or negative line, the regulator will regulate the voltage back to the correct level. Therefore called a regulator.
You will never get +8 0 -12 V!
The load regulation is something like 30 mV from 0 mA to 1 Ampere.
So you will get 11.97 0 -12V (if your op-amps use 1A on the positive rail and 0 mA on the negative rail) ((in that case i guess you probably have DC anyway, but not from the regulator offset))
Another thing: if we are talking about a tracking regulator, which by some is defined by the negative rail tracking to the output of the positive rail, what happens if the extra load happens to be on the negative rail. Will the positive rail then track that change?
right back
www.newclassd.com
Old 29th November 2004, 12:52 PM   #18
peranders's Avatar
Good question!... see my point?
Old 29th November 2004, 01:06 PM   #19
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
No, you don't.
Old 1st December 2004, 05:23 PM   #20
Banned
Lightbulb Third part (picture)
nt
Improving on LCaudio LowNoise regulatorHide this!Advertise here!
Improving the LM3x7 regulator circuit Geoff Power Supplies 206 28th December 2016 08:27 PM
lcaudio`s LN regulator Mikewong Solid State 1 31st January 2009 06:54 PM
Vbe Lowest? In lownoise bipolar transistors lineup Solid State 40 26th July 2008 12:37 AM
