Help with regulated +/- 15V PSU schematic
Old 27th November 2004, 10:11 AM   #21
lopan is offline lopan  United States
Originally posted by peranders
To be more precise: If the smoothing caps are small and you for some reason has additional smoothing on the regulated side...and the discharge time is longer in the regulated side than the unregulated, then you need these diodes but normally you don't, espcelly if you have known loads but if you are going to make a general power supply you should have these diodes, just in case. They are for protection purposes only.
I don't quite understand what you are saying. Doesn't one always have more capacitance on the regulated side. I know I will. Wouold you mind explaining this again.
Old 27th November 2004, 05:14 PM   #22
maxw is offline maxw  United Kingdom
maxw's Avatar
You always have lots of capacitance on the pre-regulator side but I think peranders is talking about having capacitance the post regulator side, ie 470uF on my schematic and these diodes protect the regs from the discharge from these caps?
Old 27th November 2004, 05:41 PM   #23
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
The point is, if you switch off the primary side, that side may fall faster than on the regulated side. That means that the output voltage could actually become higher than the input voltage, iow the reg is reverse biased, and it may be damaged. The reverse diodes make sure that the reverse voltage stays below 1V. What effectively happens is that the output caps spill over through the diodes into the input caps.
Whether this actually happens depends on the relative capacitances, the load and a couple of other things that are difficult to predict, so it is like an insurance.
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 27th November 2004, 06:54 PM   #24
Thank you. clear concise explanation
Old 27th November 2004, 07:22 PM   #25
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Example: rectifier bridge + 10000 uF + LM317 + 22-100 uF This will never create any problems.
rectifier bridge + 470 uF + LM317 + 2200 uF This _may_ create any problems.
So what Jan means is that if you don't have control over your load (know how it is), use always proetcion diodes.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 55 pcb's in order. 49 paid.
Old 27th November 2004, 07:38 PM   #26
jan.didden's Avatar
Example: rectifier bridge + 10000 uF + LM317 + 22-100 uF This will never create any problems.[snip]
Pure speculation Per. If you have a problem in your equipment so it doesn't work, for instance, and you switch it off to do fault-finding, the sec voltage will stay up long after the input caps have discharged and Boom!
Jan Didden
Old 27th November 2004, 07:42 PM   #27
maxw's Avatar
My last schematic gives +/- 13.75 BTW, I'll probably change it to +/-12 so I can use it with AD op amps though.
Old 1st December 2004, 07:13 AM   #28
maxw's Avatar
Finished!!!
I changed the layout to include a rectifier and screw terminals as this will be for testing opamps so I needed easy connectivity.
Custom mirror PCB
Costs:
transformer $26
Both Regs $8
PCB etc about $4
Caps, resisters, connectors and diodes about $17
Total approx: $55NZ = $39US
Now I just gotta make something for it to power
Old 13th December 2004, 10:31 AM   #29
costiss is offline costiss
costiss's Avatar
hope those nasty yellow caps are not tantalum... otherwise try some starget/ panasonic instead....... good work ...
i am currently using 60,000 uF of capacitance in my preamplifier..
Old 13th December 2004, 11:37 AM   #30
maxw's Avatar
They are tantalum as specified here:
http://tangentsoft.net/elec/teps/pguide.html
I dont know enough to know what is better but I know that starget would be overkill given how much they are in New Zealand
So you think small electrolytics would be better? how come?
Help with regulated +/- 15V PSU schematicHide this!Advertise here!
TL783 regulated B+ 250V PSU schematic eranrund Tubes / Valves 40 29th June 2009 08:47 AM
5V out of 12V regulated DECKY999 Power Supplies 0 7th April 2008 05:37 AM
Regulated or non-regulated SMPS longitude Class D 5 8th May 2007 03:02 PM
Regulated PSU Help.. jleaman Analogue Source 9 26th July 2004 12:36 PM
