Creating Power Supply for Computer in Car Environment
Old 1st November 2004, 07:37 PM   #1
jschen is offline jschen  United States
Default Creating Power Supply for Computer in Car Environment
I know they sell these type of units for the car environment. I have decided to try DIY project on this and need some advise. What I want to do is build a power supply for a computer. I understand that when the car is off the voltage comes from the battery (12V) and when the car is on the volts jump up to 13-14 volts. I can't remember what all the rail voltages a Motherboard needs (I need to look it up) but how would one keep the voltages stable or working voltage for a computer? Especially for an audio system that will cause voltage drops and such?
Old 2nd November 2004, 08:47 AM   #2
martin88 is offline martin88  United Kingdom
I did a quick search on google and found this link its not for a pc its for audio but it has lots of background info in it hope it helps
http://sound.westhost.com/project89.htm
And keep us posted on any progress you make
Old 2nd November 2004, 10:48 AM   #3
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
I got bored once,and decided to make a 12V input PC supply,I slapped it together in a day,and it's nothing fancy...but,it does work..
http://www.users.qwest.net/~ptaylor/...er_supply.html
Just a couple simple linear (inefficient) regulators.. with a small dc-dc converter for the -V rails. This is for an AT motherboard.For ATX,you just need to add a +3.3V regulator,and a constant source of +5V(standby).
Old 2nd November 2004, 03:26 PM   #4
Thanks for the help so far. This project probably won't be started for quite some time but getting the background info so when I get started it won't be so hard.
Old 3rd November 2004, 01:46 AM   #5
dangus is offline dangus  Canada
The forums at http://www.mp3car.com are about the best place for in-car computer information.
What kind of motherboard are you planning to use? There are very compact industrial PC boards that only require 5 volts; Pentium-class boards can be had for less than $100 on Ebay, and are fast enough for MP3 playback.
I'm going to use a switching regulator to get +5V and use a laptop drive which doesn't need 12V. Maybe add a DC-DC converter for +/-12V to run the audio circuits on the motherboard for better sound quality.
Creating Power Supply for Computer in Car EnvironmentHide this!Advertise here!
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 05:36 AM
computer power supply rev_psilocybe Chip Amps 12 6th May 2005 07:21 PM
Car computer power supply shyfx Car Audio 3 23rd August 2003 06:10 PM
