Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th November 2004, 10:50 PM   #11
alvaius is offline alvaius  Canada
Always keep in mind that a regulator is essentially a single ended amplifier. Most regulators are only pull, not push-pull though. As SAM-9 said, you now have two feedback loops to deal with. Many low current regulators are designed with quite high bandwidths, outside the audio range. Some of the higher current ones are not. Some regulators also have lots of feedback, and others have very little (and heck, a Zener and a pass-FET has as little as you can get).
So, the answer is not as easy as which is better. The design of lower current regulators coupled with the low current draw of pre-amps often makes for the best combination. However, when you get into a power stage, there may be no benefit.
Alvaius
Old 20th November 2004, 12:23 PM   #12
Send a message via AIM to HuntTheShunt Send a message via MSN to HuntTheShunt Send a message via Yahoo to HuntTheShunt
Default ClassA Power amps
Does not this statement imply that for ClassA power amps full regulation is the best option?
qoute:-
The voltage section of the power amplifier runs in pure class A, hence drawing constant currents; since it amplifies voltages, its current requirements are both fixed and low. On the other hand, voltage gain stages should have no idea what kind of load is being driven, and they introduce voltage drops over every stage, thus forcing us to increase power supply lines in order to realize the full potential of the amp.
So, we could - and I believe should, always! - use full regulation for supply lines to our voltage amplifier stages.
end quote.
from http://www.tnt-audio.com/clinica/ssps1_e.html
DiyAudio
Old 20th November 2004, 03:48 PM   #13
sam9 is offline sam9  United States
sam9's Avatar
I think yhat applies if you limit your discussion to single-ended class A. Some people may tend to assume that the class A always implies single -ended because that is a popular configuration. A dual rail class A would behave a lot like a class AB except for the output section, and thus have the potential to be fairly isolated from power supply noise, etc.
Old 20th November 2004, 04:09 PM   #14
Default Is this not for a dual rail amp?
Mind you what this person calls regulated may not be what you mean.
I suppose fully regulated means zeners or transistors used clip a high voltage down to a lower voltage and thus supply a regulated power supply.
Were he is just using full smoothing.
Or have I got it all wrong?
DiyAudio
Any traditional jazz fans out there? Bill Fitzpatrick Music 32 25th August 2008 07:15 AM
Listening axis for traditional speaker gainphile Multi-Way 6 19th May 2008 09:14 AM
Passive I/V vs. traditional I/V, FFT pics. A 8 Digital Source 49 7th June 2004 02:01 PM
Non-traditional switching supply Kilowatt Solid State 10 20th January 2002 10:06 PM
Page generated in 0.08769 seconds (73.47% PHP - 26.53% MySQL) with 11 queries
