Center tap trans.
Center tap trans.
Old 12th August 2018, 06:11 PM   #1
bluerooster is offline bluerooster
Default Center tap trans.
Just for the sake of supposing. Suppose I had a 100-0-100 transformer.
We all know that I can do a full wave rectifier, and have 100v. Or a bridge, deleting CT, and have 200v. Now, can I put a bridge between one 100 and 0, and another bridge between the other 100 and 0, and have 2 100v legs out of phase?
Thanx,
Shorty
Old 12th August 2018, 06:24 PM   #2
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
What do you mean "out of phase"?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 12th August 2018, 09:28 PM   #3
Elvee is offline Elvee  Belgium
Elvee's Avatar
Strictly speaking, getting "out of of phase" supplies from a single source/transformer is an impossibility.
If you mean two independent, floating supplies you can connect any way you want, it isn't possible either: you can connect two bridges and use the resulting supplies separately, but any attempt at connecting them galvanically downstream will result in a disaster: even trying to duplicate the normal -100/0/+100 configuration will cause shorts.
There is, in principle, a way to duplicate separate windings (not tied to a single CT): insert two capacitors in series with one of the bridges.
It is a theoretical option, but not actually practical in reality: the capacitors need to be large (ideally significantly larger than the filter caps), and because of the large value, they must be polarized, meaning you have to know the polarity they will be subjected to.
In addition, any cross-supply current will result in charging pulses through the the galvanic path connecting the supplies.
All this means that the scheme is not completely useless, just extremely limited at the very least...
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 13th August 2018, 02:12 AM   #4
PRR is offline PRR  United States
PRR's Avatar
...Suppose I had a 100-0-100 transformer.
We all know that I can do a full wave rectifier, and have 100v. Or a bridge, deleting CT, and have 200v....
Before you go there...
With the usual capacitor-input filter, 100V AC gives 141V of DC.
Going on with where I think you are going: if you want two 141VDC outputs opposite polarity around a common ground, you use -one- full wave bridge, two caps, commoned with the center-tap. That's how "all" big audio power amps do it.
Old 13th August 2018, 09:02 AM   #5
DF96 is offline DF96  England
The general answer to this type of question is that two things (in this case PSUs) cannot be both connected and isolated, yet the question is usually of the form "can I run two separate PSUs from connected secondaries?". As Elvee says, you usually end up connecting them in some way which shorts something else so it doesn't work and may cause something to get rather hot before a fuse hopefully blows.
Center tap trans.Hide this!Advertise here!
output trans for input trans Sk8Ter Tubes / Valves 33 22nd October 2016 12:13 AM
center to center spacing speakers charlie2 Multi-Way 0 4th February 2016 07:42 PM
Center-Center Distances and Horns BassAwdyO Multi-Way 8 15th January 2006 01:01 AM
Center to Center of Drivers 29" apart in proposed config - Problems?? Ken L Multi-Way 14 3rd November 2003 12:49 PM
