6.3 VDC from 6.3VAC winding? Output too low?
Old 18th July 2018, 04:31 PM   #1
Miniwatt is offline Miniwatt  Netherlands
Miniwatt's Avatar
Default 6.3 VDC from 6.3VAC winding? Output too low?
I'm trying to get 6.3VDC from a 6.3V winding. Current draw is 3.2A, the power transformer has a higher rating, so far so good.
I use a standard bridge cell and a 680 µF cap (advice from my parts salesman). Voltage drop on the rectifier is (supposed to be) 1V.
I put in the tubes (four 6N6P) and measure 5.8V! Sometimes I reach 5.9V but that's it.
I expected around 7-8V, what is going wrong? What am I missing?
The cap seemed way too small so I added 20.000 µF but that didn't change much.
Thanks in advance, kind regards.
Old 18th July 2018, 04:44 PM   #2
repycte is offline repycte  Europe
At this high current of 3.2A, this is quite challenging. In theory, the rectified voltage may reach 6.3V * sqrt(2), so around 8.8V. In pratice, this voltage is reduced by two times diode forward voltage, wiring resistance of the transformer and current draw vs. capacitance after rectifier.
By increasing the capacitor, the charge current into this capacitor will result in very high peaks. Therefore, you would need a much higher rated transformer to keep the internal resistance low and reduce the voltage drop. Also, using high current schottky diodes may help (e.g., MUR1010). Please also make sure the current ripple of the capacitor is within spec of datasheet. High ESR of the capacitor may also lead to lower charging voltage.
Finally, make sure your measurement equipment is able to measure this voltage. As there is still a high ripple voltage on the capacitor, this may lead to a faulty measurement.
You may simulate this small circuit in LTspice for validation.
Old 18th July 2018, 04:55 PM   #3
Miniwatt's Avatar
Thanks Repycte, that helped!
Old 18th July 2018, 05:06 PM   #4
Elvee is offline Elvee  Belgium
Elvee's Avatar
It should be doable, but the AC current rating of the transformer needs to be ~twice the targeted DC output current.
You then have to use large enough schottky rectifiers (>10A) and a sufficient filter cap, at least 10000µF.
If it is not sufficient, there is still a last resort option: a synchronous rectifier.
I have described one or two examples using commodity parts
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 18th July 2018, 06:25 PM   #5
Miniwatt's Avatar
So when you need 1A DC the transformer should be 2A.
This is one of the things I never really grasped, good to know, is that a general rule?
Thanks!
It's for a preamp, the breadboard version filaments were fed with AC, no hum or nothing, I'm inclined to keep using AC
Old 18th July 2018, 07:20 PM   #6
Elvee's Avatar
A power factor of 0.5 (that's what we are discussing) is not cast in bronze, and the average value is in fact closer to 0.6 (but there are exceptions in both directions), but when you demand a lot from a winding, it is prudent to adopt 0.5 or less, even if the actual rms current is not going to reach these values, because otherwise you may miss your voltage target: you are already trying to scrape tenths of volt here and there.
AC filaments have been in use for decades, even for sensitive situations and with some care and attention, you should be able to make it work.
If it really doesn't, you will always have your "cheat" option open
Old 18th July 2018, 07:33 PM   #7
Ketje is offline Ketje  Belgium
Ketje's Avatar
If you put two times two 6N6 in series you need 12.6V at 1.2A (=20Ω total).
Then this coud be a solution.
Mona
Old 18th July 2018, 08:08 PM   #8
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Or feed DC just to the first tube filament, which is the most critical, and AC to the others.
This will simplify your requirements.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 19th July 2018, 12:37 AM   #9
Miniwatt's Avatar
Makes no difference here: they are all parallel
But thanks for the tip!
Old 19th July 2018, 06:08 PM   #10
DF96 is offline DF96  England
They are only in parallel because that is how you chose to wire them. You could, if it helped, rewire them so the first one can have DC.
6.3 VDC from 6.3VAC winding? Output too low?Hide this!Advertise here!
Yet More Discussion on Winding Output Transformers 50AE Tubes / Valves 93 2nd November 2017 12:15 PM
winding an output transformer srinath Tubes / Valves 23 18th March 2013 07:21 PM
Winding output transformers M Gregg Tubes / Valves 49 18th August 2010 12:46 PM
winding a simple PP output transformer hacknet Tubes / Valves 29 13th September 2008 01:46 AM
winding a toroidal pp output Dr.Frankenstein Tubes / Valves 21 7th October 2004 07:19 AM
