30w Jean Hiraga Power Supply Design, one large capacitor or several?
Old 22nd July 2018, 06:47 PM   #121
jazz is offline jazz  Netherlands
test circuit for the psu. led's anything you have will do, just a visual check for ok. then measure voltages.
oh, what a beautifull day
I wanna go out and play!
Old 22nd July 2018, 07:38 PM   #122
vishalk is offline vishalk  United Kingdom
vishalk's Avatar
Joris thank you! I will order these up now and i can start building up the power supplies to test.
Old 22nd July 2018, 07:38 PM   #123
ohw, just dug these up. You triggered me Vishalk.
Old 22nd July 2018, 07:53 PM   #124
Perfect, hope to see you get started soon. remember, the dummy test resistors for the psu will be a perfect test load for simulating a speaker load on the amp it self if you connect four of them in parallel on one channel.
They make for an 8 Ohm load in parallel which is your standard test load on an amp channel. So they will come in handy in the future. No wasted money there.
Joris
Old 22nd July 2018, 08:21 PM   #125
vishalk's Avatar
could i just buy a 100w 8ohm resistor?
1/2/4/8/10 Ohm 100W Watt Shell Power Aluminum Housed Case Wirewound Resistor YJ | eBay
Old 22nd July 2018, 08:41 PM   #126
No. you want to simulate the load. The Hiraga draws about 1,5A. So U=IxR dictates that a load for the psu should be 28/1,5= 18,6R Two times 36 Ohm parallel gives about that. Thus you need two 36R/25W per rail. P=UxI says 42W dissipation. So 25W is risky already and therefore i adviced to clamp them to the heatsinks. They will smell burnt after a few seconds.
Also you will need two sets of those because you want to test both rails at the same time. Otherwise unbalanced loading of the circuit as a whole will have a negative influence. your measurements would not be valid/relevant.
Just get those resistors, if 50W rated units are not to much mor expensive get those. Don't skimp on numbers. Buying 10 in stead of one could get you a good deal on mouser or such. They don't need to be quality, just the rating so buy the cheapest you can clamp to the heatsinks.
Old 22nd July 2018, 08:43 PM   #127
error
Old 22nd July 2018, 08:52 PM   #128
vishalk's Avatar
Ok got it! On mouser now!
Old 23rd July 2018, 08:37 AM   #129
vishalk's Avatar
The closest i can get for the resistors at 50w is 33R or 39R.
I could always get say 30R and then 6R place them is series?
Old 23rd July 2018, 09:15 AM   #130
eduard is offline eduard  Netherlands
Send a message via Yahoo to eduard
Hello ,
Or use 10 and 8 ohm in series 100watt from ebay.
But they are only 100 watt if they are mounted on a big piece of alumium!!
They will blow with a big bang if you put to much power. I did that one time. The internal element has nowhere to go but sideways and it will.
Maybe try to find one like i posted a few post back. It is big as a big sigar and you can heat it up a lot that is why during test i put it on a piece of glass.
You dont need to connect it for hours. Usually a few minutes will do.
You could also buy something like 2.2 or 3 ohm 20 watts and put then on stand offs up in the air. But the alumium ones have a serious derating if you use them up in the air.
With several smaller ohmic values in series it will be easy to create another load.
Greetings, Ed
30w Jean Hiraga Power Supply Design, one large capacitor or several?Hide this!Advertise here!
Jean Hiraga Mc circuit NickC Analogue Source 19 3rd November 2017 02:40 PM
large capacitor array power supply board, ideal for you amp siliconray Siliconray Online Electronics Store 0 5th December 2011 05:34 AM
Jean Hiraga SE KT88 Nikon1975 Tubes / Valves 9 16th March 2010 04:50 PM
Jean Hiraga SE Amplifier Power Supply Nikon1975 Tubes / Valves 5 9th December 2009 12:44 PM
Power supply Capacitor, bad design? gain wire Solid State 6 8th December 2008 04:36 PM
