The Simplistic Salas LV 1.0 Shunt regulator
Old 23rd June 2018, 08:23 PM   #1
robertor is offline robertor  Hungary
robertor's Avatar
Default The Simplistic Salas LV 1.0 Shunt regulator
Hi everybody!
I built the small power supply to power my DAC ProJect.
12 volts required.
Available: transformer with 13.2 volt secondary, ultra fast byv diodes, ect etc, in short everything needed.
Unfortunately, where I live the minimum voltage is 238 volts with oscillations up to 240 volts.
Then the transformer delivers over 15 volts with output, after bridge and electrolytic filter capacitors, which stands at 21.3 volts.
The first 3 green LEDs light up with a nice green, while the LED next to the 1K trimmer, lowering the voltage to see to get to the 12 volts required, gradually as the voltage drops, it is a beautiful yellow color .
The trimmer manages to bring the voltage to 13.2 volts and after a few minutes I believe it has burned as there is no difference between IN and OUT.
After having bored you with all the questions: what value should the trimmer have to be able to adjust the tension and not burn?
Is the led near the trimmer and normal that it is yellow if the voltage is lowered?
in my profound ignorance I tried to mount other 2 green LEDs (so a total of 5 LEDs) to see to lower the voltage but nothing is changed indeed, with 5 LEDs is skipped the 1K trimmer.
thanks in advance for any help.
Rob
rob
Old 24th June 2018, 11:18 AM   #2
robertor's Avatar
Problem solved.
rob
Old 24th June 2018, 03:31 PM   #3
merlin el mago is offline merlin el mago
merlin el mago's Avatar
What was the issue?
Old 25th June 2018, 06:23 AM   #4
robertor's Avatar
The drawing of the scheme I had available had incorrect indications (IRF9540).
rob
Old 25th June 2018, 10:12 AM   #5
The Simplistic Salas LV 1.0 Shunt regulatorHide this!Advertise here!
The simplistic Salas low voltage shunt regulator iko Power Supplies 7762 24th June 2018 11:39 AM
